以下文件为您的要求提供了有用的信息
1)http://www.xilinx.com/support/documentation/white_papers/wp437-ZUC-Cipher-Zynq.pdf
2)http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf
3)http://www.xilinx.com/support/documentation/sw_manuals/petalinux2013_10/ug978-petalinux-zynq-amp.pdf
您使用的是XIlinx评估板吗?
(或)你自己的定制板?
如果您正在使用XIlinx evalaution board,请告知我们电路板号码。
这样我们就可以提出更具针对性的示例参考设计
_______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。
因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。
以上来自于谷歌翻译
以下为原文
The below documents give useful information for your requirement
1) http://www.xilinx.com/support/documentation/white_papers/wp437-ZUC-Cipher-Zynq.pdf
2) http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf
3) http://www.xilinx.com/support/documentation/sw_manuals/petalinux2013_10/ug978-petalinux-zynq-amp.pdf
Are you using any XIlinx evaluation board? (OR) your own custom board? If you are using XIlinx evalaution board then please let us know board number. So that we can suggest more pointed example reference designs
________________________________________________
Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer.
Give kudos to this post in case if you think the information is useful and reply oriented.
以下文件为您的要求提供了有用的信息
您使用的是XIlinx评估板吗?
(或)你自己的定制板?
以上来自于谷歌翻译
以下为原文
举报
