Microchip
直播中
杜云
8年用户 307经验值
私信 关注
[问答]
PIC12F509 XC8 C代码不会构建
您好,您知道PIC12F509的代码为什么不能编译吗?它是用MPLAB X IDE编写的,使用XC8C编译器编写的。所有的代码都是在端口GP4上选择一个低到高的过渡,然后等待3毫秒,然后取端口GP2高。我现在被建筑错误弄得眼花缭乱。
以上来自于百度翻译
      以下为原文
    Hello,
Do you know why this code for PIC12F509 will not compile?
It is written in MPLAB X IDE and using XC8 C compiler.
All the code does is pick out a low to high transition on PORT GP4 and then wait 3 ms, then take PORT GP2 high.
I am festooned with build errors at the moment.
* File: zapper.c
* Author:
* Created on 03 June 2017, 23:55
//This code turns the product ON at the mains peak voltage
//It does this by using the zero crossing detector input.
//This uses PIC12F509
//MPLAB X IDE
//XC8 C compiler (free)
#define _XTAL_FREQ 4000000
#include
#include
#pragma config OSC = ExtRC // Oscillator Selection bits (external RC oscillator)
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF // Code Protection bit (Code protection off)
#pragma config MCLRE = ON // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is MCLR)
//I have not set the MCLR pin as an input because it will be noise susceptible.
//Therefore i set MCLR up as reset, but i will never use it as reset..but will
//simply tie the pin top Vdd on the PCB.
//Define output
#define FETS LATBbits.RB2;
//Define input
#define zero_x PORTBbits.RB4;
//Define actions
#define ON LATBbits.RB2 = 1 /*Turn ON FETs*/
//Declare functions which set up the microcontroller
void disable_interrupts(void); //How do this?
void disable_pullups(void); //How do this?
void setup_ports(void);
void setup_ports(void) {
    TRISB = 0b00011000;
    return;
//Declare variables
uint8_t count;
void main(void) {
    setup_ports();
    //10 second delay
    for (count=1;count<=100;count++) {
    __delayms(100);
here:
    if {zero_x = 1} {goto here;}
here1:
    if {zero_x = 0} {goto here1;}
    //When it gets to this point, the zero crossing input has just gone high
    __delayms(3); //delay to get to the mains peak
    ON; //Turn ON FETs...at the mains peak
    while(1){;}
    return ();
回帖(8)
陈晨
2019-3-13 13:42:22
1。您没有发布生成错误。2、如果(ZooOxx=1)应该是====是一个赋值。=比较。3.那是什么样的混乱?当(ZooOxx==1)时,在C4中做同样的事情。禁用Iututs di.();5。上拉是WPUB位。
以上来自于百度翻译
      以下为原文
    1. You did not post the build errors.
2.if( Zero_x = 1) should be ==
= is an assignment.
== is a compare.
3.what is that goto mess?
while (zero_x == 1); does the same thing in C
4. Disable interupts di();
5. The pull-ups are the WPUB bit
举报
李兆峰
2019-3-13 13:49:31
定义了π末尾的分号
以上来自于百度翻译
      以下为原文
    and the semicolons at the end of #defines
举报
杨玲
2019-3-13 14:04:05
和括号周围的“如果”条件而不是括号,拼写错误的γ-Delaymis…
以上来自于百度翻译
      以下为原文
    and braces around "if" conditions instead of parentheses, and misspelling of __delay_ms...
举报
李兆峰
2019-3-13 14:22:16
我以为我看到了这样的东西,但让它去,以为我还在睡觉。
以上来自于百度翻译
      以下为原文
I thought I saw something like that but let it go, thinking I was still asleep
举报
更多回帖
