是德科技
直播中
张荷
8年用户 220经验值
私信 关注
[问答]
EXA 9010A黑屏
型号:EXA 9010A,带WinXP试用远程屏幕,用(CTL-F2?),最后用远程监视器和频谱分析仪BOTH黑屏。
我如何让他们恢复?
谢谢
以上来自于谷歌翻译
     以下为原文
  Model: EXA 9010A, with WinXP
Tried to get remote screen, with (CTL-F2?), and ended up wiht the remote monitor and spectrum analyzer BOTH with black screen. How do I get them back up?
Thanks
回帖(1)
李欢
2019-3-7 16:40:11
嗨 - 我建议执行恢复以将所有Windows XP参数重置为EXA所需的默认值。
幸运的是,您所做的不应该更改BIOS设置,并且在Windows XP启动之前,BIOS显示设置将处于活动状态。
关闭分析仪,然后重新打开。
出现黑白Agilent Technologies启动画面后,您应该会看到一个屏幕,允许您选择Windows XP Professional操作系统或Agilent Recovery System。
选择Agilent Recovery System,然后按照提示进行操作。
有关执行恢复的更多详细信息,请参阅“入门和故障排除指南”中的磁盘驱动器恢复过程主题(http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=AGILENT_EDITORIAL&
ckey = 2301280& lc = eng& cc = US& nfr = -33932.710350.00)。
执行恢复后,您需要将仪器软件升级到最新版本,以确保校准文件和FPGA代码正确同步。
问候 -
以上来自于谷歌翻译
     以下为原文
  Hi -
I recommend performing a recovery to reset all Windows XP parameters to the defaults required for the EXA. Fortunately, what you did should not have changed the BIOS settings, and it is the BIOS display settings that will be active until Windows XP starts. Turn the analyzer off and then back on again. After the black-and-white Agilent Technologies splash screen appears, you should see a screen that allows you to either select the Windows XP Professional operating system or the Agilent Recovery System. Select Agilent Recovery System, and follow the prompts.
More details on performing the recovery can be found in the Disk Drive Recovery Process topic in the Getting Started and Troubleshooting Guide (http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=AGILENT_EDITORIAL&ckey=2301280&lc=eng&cc=US&nfr=-33932.710350.00 ). You will need to upgrade the instrument software to the latest after performing the recovery to ensure that calibration files and FPGA code are properly synchronized.
Regards -
举报
更多回帖
