Kintex-7部件中GTX的最高速度取决于速度等级和封装类型。
参见表53中的DS182,您将看到在FB封装(无盖倒装芯片)中,所有速度等级的最大速度为6.6Gbps。
FF(高性能倒装芯片)中的器件速度更快,其中性能随速度等级而增加,-3能够达到12.5Gbps。
XCK70T只有两个封装,它们都是FB封装...请参阅Kintex-7产品表,查看可用的器件和封装组合。
Avrum
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
The maximum speed of the GTX in the Kintex-7 parts depends on both the speed grade and the
package type. Refer to DS182, Table 53, and you will see that in the FB packages (the lidless flip-chip), the maximum speed is 6.6Gbps for all speed grades. The speed is faster for devices in the FF (high performance flip-chip), where the performance increases with speed grade, with the -3 able to go 12.5Gbps.
The XCK70T only comes in two packages, and they are both FB packages... Refer to the Kintex-7 Product Table to see the combinations of devices and packages that are available.
Avrum
View solution in original post
Avrum
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Avrum
举报
