亲爱的所有我正在解决vna / pna如何计算单端口校准的错误条款,即EDF,ESF和ERF来自这里的定义
[http://na.tm.agilent.com/pna/
caldefs / stddefs.html]。
我知道先生Joel P. Dunsmore先生在*“微波
元件测量手册:先进的VNA技术手册”*中给出的公式(附件)。
我遇到的问题是负载的实际反射系数,开路和短路,因为我不知道* 85052C校准套件*的这些标准的响应。
如果我可以获得该套件的基于数据的校准文件,那么它将非常有用,但是这个套件在安捷伦网站上没有。
我可以得到的是开路和电感值的电容值,但我不知道如何使用它们来计算开路,短路和负载的实际(模型)反射系数值,以及
得到错误条款。
期待专家的帮助。
感谢你在期待。
以上来自于谷歌翻译
以下为原文
Dear all
I am in a fix as to how a vna/pna calculates the Error Terms for a one port calibra
tion namely EDF,ESF and ERF from the definations such as here [
http://na.tm.agilent.com/pna/caldefs/stddefs.html] . I know the formula(attached) given in *"Handbook of Microwave Component Measurements: with Advanced VNA Techniques"* by sir Joel P. Dunsmore. The problem I am encountering are with the actual reflection coefficients of the load,open and short as I don't know the response of these standards of the *85052C Calibration Kit*. If I can get a data based calibration file for this kit then it would be very helpful but there is none for this kit on the agilent website.
What is available to me are the capacitance values for open and inductance values for short,but I don't know how to use these to calculate the actual(model) reflection coefficient values for the open,short and load to put in this formula and get the Error terms.
Looking forward for the experts help. Thanking you in anticipation.
附件
