如果打开2个通道,则根据定义,它们是同步的,并且将从同一触发器捕获数据。
可能存在很小的通道到通道偏斜,但它可能足够接近零,您不必担心它。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。
安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
If 2 channels are turned on, they are, by definition, synchronized, and will capture data from the same trigger. There might be a small of channel-to-channel skew, but it will probably be close enough to zero that you don't need to worry about it.
Al
Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
以上来自于谷歌翻译
以下为原文
Al
举报
