Microchip
直播中
张宁
8年用户 189经验值
私信 关注
[问答]
Pickit3无法下载RS
因此,PICtiT3被卡住下载RS。…给我的是,我一直在这个程序员2-3年,不是最可靠的,而是足够的。我正在尝试为一个成熟的项目编程一个新的引导加载程序,它不会通过下载RS。…?
以上来自于百度翻译
      以下为原文
    So, the Pickit3 is stuck downloading the RS . . .  What gives, I have been with this programmer 2-3 years not the most reliable but adequate. I am trying to program a new bootloader to a mature project and it wont get past Downloading RS . . . ?
回帖(4)
杨叶
2019-2-21 15:26:45
嗨,看看各种类似的问题,安装旧的MPLAB版本(V892)和用PICTIT3编程将迫使旧的固件,然后当回到MPLAB X时,它最有可能会成功。
以上来自于百度翻译
      以下为原文
    Hi,
Looking at various similar issues, installing the older MPLAB version (v8.92) and programming with Pickit3 will force an older firmware and then when coming back to MPLAB X it most probably will succed.
Regards
举报
李铭鑫
2019-2-21 15:35:48
嗨,什么版本的MPLAB X?不同版本的MPLAX X有不同的bug,最近有没有更新MPLAX?MPLAB X V3.61一直在为我工作。V3.65似乎比以往任何时候都糟糕。RISC建议的治疗通常对我来说是有效的,但是它可能有助于MPLAB 8.92做一个完整的固件更新:选择菜单:“调试器”的设置……这将打开一个对话框:PICIT 3 StutsSSELECT选项卡:“配置”打开:“手动下载”和“选择:P”。K3FWY012890.0.JAMIF MPLAB X固件更新再次卡住,等待直到您确定没有发生什么,退出MPLAB X,拔出皮卡3并再次插入它,然后重新启动MPLAB X。您可能必须再次选择PIDIT 3作为调试器工具。如果它到达:下载AP…那么您已经领先了一步。迈西尔
以上来自于百度翻译
      以下为原文
    Hi,
What version of MPLAB X ?
Different versions of MPLAB X have different bugs.
Any update of MPLAB X recently?
MPLAB X v3.61 have been working o.k. for me. v3.65 seem to be worse than ever.
Cure suggested by RISC usually seem to work for me,
it may however help to ask MPLAB 8.92 to do a full firmware update:
Select menu: 'Debugger' 'Settings...'
This will open a dialog box: PICkit 3 Settings
Select Tab: 'Configuration'
Open:  'Manual Download'  and select:  PK3FW_012890.jam
If MPLAB X firmware update get stuck again,
wait until you are sure nothing happen, Exit MPLAB X, Unplug PICkit 3 and plug it in again, then Restart MPLAB X. You may have to select PICkit 3 as debugger tool again.
If it get to: Downloading AP ...
then you have got one step ahead.
   Mysil
举报
潘璐
2019-2-21 15:53:36
这也是我的经验。一般来说,3.6x比3.5Xin以前的版本更糟糕,至少它最终会因连接错误而超时,并且我可以点击仪表板中的“刷新调试工具状态”按钮(两个圆形箭头),并继续下一步编程工具。永远不要超时。它只会被诸如“下载RS”、“下载AP”等消息所困扰。我发现我必须拔掉这个工具,重新启动MPLABX/IPE,然后再试一次。这真是令人沮丧。自从他们切换到WiNUSB,我遇到了所有MPLABX生成程序与工具对话的问题,而且似乎越来越糟,而不是更好。“过时的/我们需要修复它”MPLAB8就像所有工具的魅力一样。
以上来自于百度翻译
      以下为原文
That's my experience also. In general, 3.6x is worse than 3.5x
In previous versions at least it would eventually timeout with a connection error and I could click the "Refresh Debug Tool Status" button in the dashboard (the two circular arrows) and it would continue on with the next step in programming the tool.
With v3.65 it never times out. It just get stuck with messages like "downloading RS", "downloading AP", etc. I find I have to unplug the tool, restart mplabx/IPE and try again.
This is incredibly frustrating. Ever since they switched to winUSB I've had problems with ALL the mplabx-generation programs talking to the tools, and it seems to be getting worse, not better. The "outdated/we need to fix it" MPLAB8 works like a charm with all the tools.
举报
李兆峰
2019-2-21 16:09:46
我正在使用3.65的PIC24项目这些天(可能是第一次,在PIC32一个去年冬天),我不会说它比以前更糟:只是通常的精神病编辑和标准慢度,无用的弹出窗口,无用的开始页面…但它确实可以工作,可以通过我的ICD3编程…
以上来自于百度翻译
      以下为原文
    I am using 3.65 for a PIC24 project these days (possibly first time, after the PIC32 one last winter) and I would not say it's worse than before: just the usual psychopath editor and standard slowness, useless popups, useless start page... but it does work and can program via my ICD3...
举报
更多回帖
