Microchip
直播中
杨嘉怡
7年用户 232经验值
私信 关注
[问答]
USB3主机与RealICE(和ICD3)不兼容?
我仍然沉溺于一台新的计算机,我想我发现在我的坞站中的USP3主机与Realice(和ICD3)不兼容。也就是说,当我将这些设备连接到码头时,它们的灯就像它们正在工作一样活跃,但是MPLABX IDE和IPE无法找到它们。将它们直接插入笔记本电脑(或者甚至通过USB总线到笔记本电脑),它们工作得很好,但是当我想从我的微软的UBVIEW中调试出一个快速的信息时,就出现了一个机械问题(参见HTTPS://DOCS.MySoF.CON/EN-U/WANDOWS硬件/驱动程序/调试/ U)。收益率:ASMENTUB3.0可扩展主机控制器DRIKEVIKEY:{36FC9E60-11CF-80C68054-4355354000 } 00 08VANDORID:1B21DEVICIDID:1142SySysID:B054 1028修订:00调试端口号:NoeBuff.DeVICE函数(十进制):120.0.主机控制器电源状态映射系统状态主机控制器ROOT集线器USB唤醒POWEDES0(工作)D0 D0 S1(睡眠)D?(未指定)D?(未指定)S2(睡眠)D?(未指定)D?(未指定)S3(睡眠)D3 D3是YES4(Hibernate)D3 D3是YEST睡眠状态S?(未指定)USB XHCI兼容主机控制器…作为冒犯主机控制器。有趣的是,微软工具甚至看不到连接到这个主机的设备。(一些新的UB3缺乏向后可比性?)还有人见过这样的事吗?
以上来自于百度翻译
      以下为原文
    Still settling into a new computer, and I think I've found out that the USB3 host in my docking station is incompatible with the RealICE (and the ICD3).  i.e., when I connect those devices to the dock, their lights are active as if they were working, but the MPLABX IDE and IPE cannot find them.  Plug them directly into the laptop (or even thru a u***3 hub to the laptop) and they work just fine, but present a mechanical problem when I want to make a quick getaway from my cubical...
Debugging info from microsoft's u***view
(see https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/u***view) yields:
ASMedia USB3.0 eXtensible Host Controller
DriverKey: {36fc9e60-c465-11cf-8056-444553540000}008
VendorID: 1B21
DeviceID: 1142
SubSysID: B0541028
Revision: 00
Debug Port Number: None
Bus.Device.Function (in decimal): 12.0.0
Host Controller Power State Mappings
System State Host Controller Root Hub USB wakeup Powered
S0 (working) D0 D0
S1 (sleep) D? (unspecified) D? (unspecified)
S2 (sleep) D? (unspecified) D? (unspecified)
S3 (sleep) D3 D3 Yes Yes
S4 (Hibernate) D3 D3 Yes Yes
Last Sleep State S? (unspecified)
USB xHCI Compliant Host Controller
...as the offending host controller.  Funny enough the microsoft tool can't even see devices that are connected to this host.  (some new USB3 lack of backwards comparability?)  Anyone else ever see anything like this?
回帖(2)
陈刚
2019-2-18 14:20:55
更新的驱动程序解决了ITH.HTTP//www. del.COM/Sputt/HOME/USE/En/19/Drime/DrimeSealthDebug?DRIVIDID=M8TKT和FielID=3695130011和OSCODE=WT64 A&Apple;
以上来自于百度翻译
      以下为原文
    updated driver solved it...
http://www.dell.com/support/home/us/en/19/drivers/driversdetails?driverId=M8TKT&fileId=3695130011&osCode=WT64A&productCode=precision-15-7520-laptop&languageCode=en&categoryId=DK
举报
杨叶
2019-2-18 14:35:46
请在线程标题中添加[解决]
以上来自于百度翻译
      以下为原文
    please add [SOLVED] in your thread title
举报
更多回帖
