Cypress技术论坛
直播中
张婷婷
8年用户 239经验值
私信 关注
[问答]
DDR2+SRAM IBIS模型中的ODT看不到
嗨,DDR2+SRAM部件应该在数据线上有ODT…但我在iBIS模型中看不到。我在BWS和K/K*上看到了。
来自DDR2PB2L25YCY21XX.IBS的例子(您可以看到它在哪里表示驱动输出阻抗是什么,但是输入阻抗未知):
[模型选择器] TATAIO TATAIO5050TT1.5 1.5数据模型(50OHMS)在TT条件下:1.5V I/O DATAIO5050FF1.51.5 DATAIO模型(50OHMS)在FF条件下:1.5V I/O DATAIO50TSFF1.5 1.5DATAIO模型(50OHMS)在tiP慢速条件下-1.5V I/O DATAIO30TTY1.5 1.5DATAIO模型(30OHMs)在TT条件下- 1在FF条件下的5V I/O DATAIO30FF1.51.5 DATAIO模型(30OHMs)-1.5V I/O DATAIO30TSF1.51.5 DATAIO模型(30OHMS)在TIP慢速条件下-1.5V I/O DATAIO40TT1.51.5 DATAIO模型(40OHMS)在TT条件下-1.5V I/O DATAIO40FF1.51.5 DATAIO模型(40OHMs)在FF条件下-1.5V I/O DATAIO40TYF1.51.5 DATAIO模型(40OHMS)在TYP慢速条件下-1.5V I/O DATAIO60TTY1.5 1.5DATAIO模型(60OHMS)在TT条件下-1.5V I/O DATAIO60FF1.51.5 DATAIO模型(60OHMS)在FF条件下1.5V I/O DATAIO60TSFF1.5 1.5DATAIO模型(60OHMS)在TIP慢速条件下-1.5V I/O DATAIO70TTY1.5TAT条件下的DATAIO模型(70OHMS)-1.5V I/O DATAIO70FF1.51.5 DATAIO模型(70OHMs)在FF条件下-1.5V I/O
谢谢您。
以上来自于百度翻译
     以下为原文
  Hi, the DDR2+ SRAM parts are supposed to have ODT on the DATA lines... but I don't see it in the ibis model.  I see it on the BWS and K/K* though.
    Example from ddr2pb2l25_cy21xx.ibs (You can see where it says what the driving output impedance is, but the input impedance is unknown):
    [Model Selector]    DATAIO
DATAIO50_TT_1.5   DATAIO models (50ohms) at TT conditions - 1.5V I/O
DATAIO50_FF_1.5   DATAIO models (50ohms) at FF conditions - 1.5V I/O
DATAIO50_TSF_1.5  DATAIO models (50ohms) at Typ Slow Fast conditions- 1.5V I/O
DATAIO30_TT_1.5   DATAIO models (30ohms) at TT conditions - 1.5V I/O
DATAIO30_FF_1.5   DATAIO models (30ohms) at FF conditions - 1.5V I/O
DATAIO30_TSF_1.5  DATAIO models (30ohms) at Typ Slow Fast conditions- 1.5V I/O
DATAIO40_TT_1.5   DATAIO models (40ohms) at TT conditions - 1.5V I/O
DATAIO40_FF_1.5   DATAIO models (40ohms) at FF conditions - 1.5V I/O
DATAIO40_TSF_1.5  DATAIO models (40ohms) at Typ Slow Fast conditions- 1.5V I/O
DATAIO60_TT_1.5   DATAIO models (60ohms) at TT conditions - 1.5V I/O
DATAIO60_FF_1.5   DATAIO models (60ohms) at FF conditions - 1.5V I/O
DATAIO60_TSF_1.5  DATAIO models (60ohms) at Typ Slow Fast conditions- 1.5V I/O
DATAIO70_TT_1.5   DATAIO models (70ohms) at TT conditions - 1.5V I/O
DATAIO70_FF_1.5   DATAIO models (70ohms) at FF conditions - 1.5V I/O
    Thank you.
回帖(2)
王建华
2019-2-18 15:39:56
你好,韦斯特克,
数据输入也有ODT。请确认您是否在以下链接中引用最新的IIS模型:
HTTP://www. CyPress?COM/?RID=48344
下面是IIS模型中的ODT缓冲区模型。
[模型选择器]输入板
在TT条件下输入525TTH1.5 1.5输入模型(52.5OHMs)-1.5V I/O
在FF条件下输入525FFF1.5输入模型(52.5欧姆)-1.5V I/O
在TypSlowFast条件下输入525TSFF1.5输入模型(52.5OHMs)-1.5V I/O
在TT条件下输入输入模式(75欧姆)-1.5V I/O
在FF条件下输入输入模式(75欧姆)-1.5V I/O
输入条件:TypSlowFast条件下输入模式(75欧姆)-1.5V I/O
在TT条件下输入- 90TTH1.5 1.5输入模式(90欧姆)-1.5V I/O
在FF条件下输入90FFF1.5输入模式(90欧姆)-1.5V I/O
输入条件90-TSF1.51.5输入模式(90欧姆)在TypSlowFast条件-1.5V I/O
在TT条件下输入105TTH1.5 1.5输入模型(105OHMs)-1.5V I/O
在FF条件下输入105FFF1.5输入模型(105OHMs)-1.5V I/O
在TypSlowFast条件下输入105TSFF1.5输入模型(105OHMs)-1.5V I/O
在TT条件下输入模式150(150欧姆)-1.5V I/O
在FF条件下输入输出模式(150欧姆)-1.5V I/O
input150_tsf_1.5输入模型(150ohms)在TypSlowFast条件Vgs=- 1.5V的I / O
input525_tt_1.8输入模型(52.5ohms)在TT条件为1.8V的I / O
input525_ff_1.8输入模型(52.5ohms)在FF条件为1.8V的I / O
input525_tsf_1.8输入模型(52.5ohms)在TypSlowFast条件为1.8V的I / O
input75_tt_1.8输入模型(75ohms)在TT条件为1.8V的I / O
input75_ff_1.8输入模型(75ohms)在FF条件为1.8V的I / O
input75_tsf_1.8输入模型(75ohms)在TypSlowFast条件为1.8V的I / O
input90_tt_1.8输入模型(90ohms)在TT条件为1.8V的I / O
input90_ff_1.8输入模型(90ohms)在FF条件为1.8V的I / O
input90_tsf_1.8输入模型(90ohms)在TypSlowFast条件为1.8V的I / O
input105_tt_1.8输入模型(105ohms)在TT条件为1.8V的I / O
input105_ff_1.8输入模型(105ohms)在FF条件为1.8V的I / O
input105_tsf_1.8输入模型(105ohms)在TypSlowFast条件为1.8V的I / O
input150_tt_1.8输入模型(150ohms)在TT条件为1.8V的I / O
input150_ff_1.8输入模型(150ohms)在FF条件为1.8V的I / O
input150_tsf_1.8输入模型(150ohms)在TypSlowFast条件为1.8V的I / O
当做
贾亚斯里
以上来自于百度翻译
     以下为原文
   Hi Westec,
              The data inputs also have ODT.Please confirm whether you are referring to the latest IBIS model on the web in link below:
    http://www.cypress.com/?rID=48344
    Below are the ODT buffer model in the IBIS model.
    [Model Selector]    INPAD
    INPUT525_TT_1.5  INPUT models(52.5ohms) at TT conditions - 1.5V I/O
    INPUT525_FF_1.5  INPUT models(52.5ohms) at FF conditions - 1.5V I/O
    INPUT525_TSF_1.5 INPUT models(52.5ohms) at TypSlowFast conditions- 1.5V I/O
    INPUT75_TT_1.5   INPUT models (75ohms) at TT conditions - 1.5V I/O
    INPUT75_FF_1.5   INPUT models (75ohms) at FF conditions - 1.5V I/O
    INPUT75_TSF_1.5  INPUT models (75ohms) at TypSlowFast conditions- 1.5V I/O
    INPUT90_TT_1.5   INPUT models (90ohms) at TT conditions - 1.5V I/O
    INPUT90_FF_1.5   INPUT models (90ohms) at FF conditions - 1.5V I/O
    INPUT90_TSF_1.5  INPUT models (90ohms) at TypSlowFast conditions- 1.5V I/O
    INPUT105_TT_1.5  INPUT models (105ohms) at TT conditions - 1.5V I/O
    INPUT105_FF_1.5  INPUT models (105ohms) at FF conditions - 1.5V I/O
    INPUT105_TSF_1.5 INPUT models (105ohms) at TypSlowFast conditions- 1.5V I/O
    INPUT150_TT_1.5  INPUT models (150ohms) at TT conditions - 1.5V I/O
    INPUT150_FF_1.5  INPUT models (150ohms) at FF conditions - 1.5V I/O
    INPUT150_TSF_1.5 INPUT models (150ohms) at TypSlowFast conditions- 1.5V I/O
    INPUT525_TT_1.8  INPUT models(52.5ohms) at TT conditions - 1.8V I/O
    INPUT525_FF_1.8  INPUT models(52.5ohms) at FF conditions - 1.8V I/O
    INPUT525_TSF_1.8 INPUT models(52.5ohms) at TypSlowFast conditions- 1.8V I/O
    INPUT75_TT_1.8   INPUT models (75ohms) at TT conditions - 1.8V I/O
    INPUT75_FF_1.8   INPUT models (75ohms) at FF conditions - 1.8V I/O
    INPUT75_TSF_1.8  INPUT models (75ohms) at TypSlowFast conditions- 1.8V I/O
    INPUT90_TT_1.8   INPUT models (90ohms) at TT conditions - 1.8V I/O
    INPUT90_FF_1.8   INPUT models (90ohms) at FF conditions - 1.8V I/O
    INPUT90_TSF_1.8  INPUT models (90ohms) at TypSlowFast conditions- 1.8V I/O
    INPUT105_TT_1.8  INPUT models (105ohms) at TT conditions - 1.8V I/O
    INPUT105_FF_1.8  INPUT models (105ohms) at FF conditions - 1.8V I/O
    INPUT105_TSF_1.8 INPUT models (105ohms) at TypSlowFast conditions- 1.8V I/O
    INPUT150_TT_1.8  INPUT models (150ohms) at TT conditions - 1.8V I/O
    INPUT150_FF_1.8  INPUT models (150ohms) at FF conditions - 1.8V I/O
    INPUT150_TSF_1.8 INPUT models (150ohms) at TypSlowFast conditions- 1.8V I/O
    regards
    Jayasree
举报
张婷婷
2019-2-18 15:56:53
嗨,Jayasree,
是的,这是一个很好的例子模型(我已经看过DealalCio模型……一切非常相似。
InPad确实有ODT,但没有分配给数据。数据使用DATAIMODEL(我粘贴的一个)检查[PIN ]列表:
B2-DQ27数据
再次感谢约瑟夫
以上来自于百度翻译
     以下为原文
  Hi Jayasree,
    Yes that's a good example model (I've looked at several CIO models... all very similar.)
    The INPAD does have ODT, but is not assigned to Data.  Data use the DATAIO model (the one I pasted.)  Check the [Pin] list:
    B2              DQ27              DATAIO
    Thanks again,
Joseph
举报
更多回帖
