是德科技
直播中
张艳梅
7年用户 227经验值
私信 关注
[问答]
IVI驱动程序是否支持GCA或Intermod测量?
我安装了IVI驱动程序,版本1.1.8与PNA-X一起使用。
似乎只有s参数测量可用;
是否支持GCA或Intermod测量?
谢谢,马克
以上来自于谷歌翻译
     以下为原文
  I've installed the IVI driver, version 1.1.8 to use with a PNA-X. It appears that only s-parameter measurements are available; is there any support for GCA or Intermod measurements?
Thanks,
Mark
回帖(2)
卢兰凤
2019-2-15 16:14:57
IVI驱动程序中没有测量应用程序。
我建议您查看Agilent Command Expert,这是一款免费工具,可与PNA-X和许多其他仪器配合使用,以协助多种语言编程,并支持仪器的整个SCPI接口。
以上来自于谷歌翻译
     以下为原文
  The measurement applications are not available in the IVI driver.  I recommend taking a look at Agilent Command Expert which is a free tool that works with the PNA-X and many other instruments to assist with programming in multiple languages and supports the entire SCPI interface of the instrument.
举报
张博
2019-2-15 16:25:54
您好,如果您使用IVI驱动程序+设置,那么您需要对所有非集成命令使用Pass Thru命令,例如GCA,IMD,Time Domain和许多其他非固有集成的高级功能
IVI驱动程序中的直接函数调用。
通过调用+ agilentNAClass.System.IO.IO.WriteString(“YourCommandHere”)+类型调用来调用pass thru。
还有一个等效的READ。
真诚的,tsilchia
以上来自于谷歌翻译
     以下为原文
  Hello,
If you are +set on using an IVI driver+ then you would need to use the Pass Thru command for all non-integrated commands, such as GCA, IMD, Time Domain and a multitude of other advanced capabilities that are not inherently integrated as a direct function call within the IVI driver.
The pass thru is invoked via a call to the +agilentNAClass.System.IO.IO.WriteString("YourCommandHere")+ type call. There is an equivalent READ as well.
Sincerely,
tsilchia
举报
更多回帖
