Cypress技术论坛
直播中
范琴英
7年用户 195经验值
私信 关注
[问答]
编程不工作SPC超时
我继续得到这个错误(见下文)。我使用一个自定义的主板布局与cy8c3244lti-130es2芯片。有人知道为什么会发生这样的事情吗?我有一个miniprog3 rev5编程器/调试器和板连接到相应的10针连接器匹配。请帮忙?
dbg.m0023:有一个错误,而编程设备:(PSoC Creator收到错误(100 -失败!SPC轮询超时。与芯片失去通信
以上来自于百度翻译
     以下为原文
  I keep on getting this error (see below). I am using a custom board layout with a CY8C3244LTI-130ES2 chip. Does anyone know why this is happening or how to fix it? I have a MiniProg3 Rev5 programmer/debugger and the board is connected to the appropriate 10 pin connector to match. help please?
    dbg.M0023: There was an error while programming the device: (PSoC Creator received error (100 - FAILED! Timeout of SPC polling. Lost communication with chip.))
回帖(13)
王浩
2019-2-15 13:15:35
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
范琴英
2019-2-15 13:24:05
以上来自于百度翻译
     以下为原文
  yes
举报
王浩
2019-2-15 13:42:12
你好,莫迪,
那时没有轻松的出路。
你必须从基础开始,验证你的电路。你可能想在一个已知的工作板上验证你的程序员。如果使用SWD,记住编程时钟必须是PSoC freq.的1/3或更少。
祝你好运
以上来自于百度翻译
     以下为原文
  Hi maudi,
    No easy way out then.
    You would have to start with the basics and verify your circuit.
You may want to verify your programmer on a known working board.
If you are using SWD remember the programming clock must 1/3 or less of the PSoC freq.
    Good luck
举报
王建华
2019-2-15 13:49:40
请试试这个方法:
连接miniprog3连接到PC miniprog3 10针连接器目标打开程序员执行程序功能的SPC轮询错误执行任何其他程序的功能(校验,读,验证,执行程序编程或擦除。)成功的让我知道这可以为你工作了。
谢谢,
以上来自于百度翻译
     以下为原文
  Please try this workaround:
  • Connect Miniprog3 to PC
  • Connect Miniprog3 10 pin connector to target
  • Open Programmer
  • Execute Program Function
  • SPC polling Error
  • Execute any function other than Program (checksum, read, verify, or erase.)
  • Execute Program
  • Programming Successful
    Let me know if this can work out for you.
    Thanks,
    --Meng
举报
更多回帖
