是德科技
直播中
张兰英
8年用户 169经验值
私信 关注
[问答]
怎么使用初始网格选项
亲爱的所有,在关于FEM模拟的初始网格选项的EMPro / ADS文档中,有以下短语:*初始目标网格尺寸(A)和初始最小网格尺寸(B)之间的比率不能低于10,以提供
有足够的自由度用四面体填充解空间。*请您澄清它的含义?
这意味着:A / B> 0.1或A / B最好的问候,Angelo
以上来自于谷歌翻译
     以下为原文
  Dear All,
in the EMPro/ADS Documentation about Initial Mesh Options for FEM Simulations, there's the following phrase:
*The ratio between the Initial Target Mesh Size (A) and Initial Minimum Mesh Size (B) cannot be lower than 10 to provide the mesher enough freedom to fill the solution space with tetrahedra.*
Could you please clarify the meaning of it?
is it meant: A/B>0.1 or A/B<0.1?
Best regards,
Angelo
回帖(1)
鄢蓉
2019-2-12 11:59:49
初始目标网格是最大的网格,初始最小网格是最小的。
开始时配给量应大于10。
您可以调整这些值,但请尽可能使用“自动”。
以上来自于谷歌翻译
     以下为原文
  Initial Target Mesh is largest mesh to start with and Initial Minimal Mesh is the smallest. The ration should be larger than 10 to start with. You can tweak these values but please use "automatic" as much as possible.
举报
更多回帖
