是德科技
直播中
孙喆
7年用户 168经验值
私信 关注
[问答]
PNA-X IMD应用程序的源到音分配
您好,我正在使用带有内部两个源,组合器的双端口N5242A PNA-X,带选项-087(IMD应用程序)。
我一直在尝试使用IMD应用来测量IP2并在扫描功率干扰信号的情况下获得灵敏度。
例如,假设我在2.45 GHz处有所需的音调,干扰音调为5.5 GHz。
我希望在固定引脚= -30 dBm时保持2.45 GHz,同时将5.5 GHz干扰功率从-20 dBm扫描到+10 dBm。
与此同时,我将测量IIP2Hi,IIP2Lo,2.45 GHz的ToneGainLo和5.5 GHz的ToneGainHi。
我遇到的问题是,为了达到我想要的干扰功率扫描范围,我需要使用Source 1作为我的干扰源(因为合成器丢失使得Source 2无法达到我想要的最大干扰功率)。
在IMD应用程序设置中我发现f1在IMD应用程序中,有没有办法让Src 1(具有更高可用端口功率的那个)成为我更高的频率音调而Src 2是我的低频率音调?
我希望能够执行此测试,而无需重新配置测试装置以包含外部放大器。
谢谢
以上来自于谷歌翻译
     以下为原文
  Hello,
I'm using a two port N5242A PNA-X with the internal two sources, combiner, with option -087 (the IMD application).
I've been trying to use the IMD app to measure IP2 and gain desense in the presence of a swept power jamming signal.
For example, let's say I have a desired tone at 2.45 GHz and a jamming tone is at 5.5 GHz.
I want to hold 2.45 GHz at fixed Pin=-30 dBm while sweeping the 5.5 GHz jammer power from -20 dBm through +10 dBm.
At the same time I would measure IIP2Hi, IIP2Lo, the ToneGainLo at 2.45 GHz, and the ToneGainHi at 5.5 GHz.
The problem I'm having is that, in order to achieve my desired jammer power sweep range, I need to use Source 1 as my jammer source (because the combiner loss makes Source 2 not able to reach my desired max jammer power).
In the IMD app setup I find that f1 In the IMD application, is there any way to make Src 1 (the one having higher available port power) be my higher freq tone and Src 2 be my lower freq tone?
I'd like to be able to perform this test without needing to reconfigure the test set to include an external amplifier.
Thanks
回帖(2)
孔德羲
2019-1-30 11:08:53
你可以反转PNA背面的环路,将光源3发送到主臂,将源2发送到耦合臂,然后激光器3将具有高频率和高功率。
(不是 - 完全 - 你要求的,但也许它适合你)。
以上来自于谷歌翻译
     以下为原文
  you could reverse the loops on the back of the PNA to send source 3 to the main arm and source 2 to the coupled arm, then the soruce 3 will have high frequency and high power. (Not -exactly- what you asked for, but maybe it works for you).
举报
孔德羲
2019-1-30 11:14:59
这是路径配置的片段
以上来自于谷歌翻译
     以下为原文
  here's a snippet from the path configuration
附件
举报
更多回帖
