是德科技
直播中
韩冬
7年用户 117经验值
私信 关注
[问答]
在ENA 5071C上是否可以保存未打包相位的Touchstone文件?
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
回帖(5)
贾永世
2019-1-29 14:26:48
亲爱的BobMag很抱歉迟到的回复。
不幸的是,ENA不支持使用展开阶段保存touchstone文件。
以上来自于谷歌翻译
     以下为原文
  Dear BobMag
Sorry for late reply.
Unfortunately, ENA does not support to save touchstone file with unwrapped phase.
举报
刘华湘
2019-1-29 14:35:51
可能不是你想要的简单答案,但这里有一个小C#方法,可以自己解开相位;
以防万一你倾向于自己动手:-) / * * public static double [] PhaseUnwrap(double [] data)* * Version 1.0 - Nov 2008 * *描述:* unwrap阶段* *要求:*
数据以度为单位*所有数据元素都在+180.0和-180.0之间(包括)* mag(相位斜率)小于180(非包裹点之间的差异)* * / public static double [] PhaseUnwrap(double []
数据){double [] newdata;
double offset = 0.0;
newdata = new double [data.Length];
newdata [0] = data [0];
for(int i = 1; i 180.0){offset + = 360.0;
} else if((data [i - 1] - data ){offset - = 360.0;} newdata = data + offset;} return newdata;}抱歉搞乱的代码语法 -
愚蠢的论坛引擎认为“[['”]]之间的所有内容都是URL。旧的论坛软件有一个特殊的标签用于放置代码片段而不试图将它们重新解释为HTML
以上来自于谷歌翻译
     以下为原文
  Probably not the simple answer you were looking for, but here is a small C# method for unwrapping the phase yourself; just in case you are inclined to take matters into your own hands :-)
         * public static double[] PhaseUnwrap(double[] data)
         * Description:
         *      unwrap phase
         * Requirements:
         *      data is in degrees
         *      all elements of data are between +180.0 and -180.0 (inclusive)
         *      mag(phase slope) is less than 180 (difference between non-wrapped points)
            double[] newdata;
            newdata = new double[ data.Length ];
            newdata[0] = data[0];
            for (int i = 1; i 180.0)
                    offset += 360.0;
                else if ((data[i - 1] - data) < -180.0)
                    offset -= 360.0;
            return newdata;
Sorry about the messed up code syntax - the stupid forum engine thinks everything in between "[[' "]]" is URL.  The old forum software had a special tag for placing code snippets without trying to reinterpret them as HTML
举报
韩冬
2019-1-29 14:46:17
数据以度为单位*所有数据元素都在+180.0和-180.0之间(包括)* mag(相位斜率)小于180(非包 ...
谢谢你的建议。
我有一个常用的例程,与你的类似。
我会试试你的。
短发
以上来自于谷歌翻译
     以下为原文
  Thanks for the suggestion.  I have a routine I have been using that is similiar to yours.  I'll give yours a try.
Bob
举报
韩冬
2019-1-29 15:04:30
谢谢你的建议。
我有一个常用的例程,与你的类似。
我会试试你的。
短发
以上来自于谷歌翻译
     以下为原文
Bob
举报
更多回帖
