你好,
我试图调试一个CY8CKIT-059(CY8C588L
ti-LP097设备)编程与Acode示例从CyPress与MixPrim3和PSoC创建者4。
程序员和设备目标是可见的,我能够连接到设备(使用外部或3.3/5VTARG
电源)。这个项目建立得很好,我在命令窗口中得到一个输出,说明目标已经被正确地编程了。
然后,当它试图切换到调试模式时,我得到这个错误:
“错误:dg.M90015:调试器在运行期间意外退出。遇到错误(目标断开参见输出窗口以获取更多信息)。
显示细节标签:
“调试会话期间存在未处理的错误。这就迫使调试器关闭。再试一次。”
即使我再试一次,它也不起作用。
然后我试着用PSoC Creator 3.3,我可以调试。有人能在PSoC造器4上解决这个问题吗?
当做,
沙维尔
以上来自于百度翻译
以下为原文
Hello,
I am trying to debug a CY8CKIT-059 (CY8C5888LTI-LP097 device) programmed with a code example from Cypress with a MiniProg3 and PSoC creator 4.0 .
The programmer and device target are visible and I am able to connect to the device (using external or 3.3/5Vtarg power supply). The project builds well and I get an output in the command window that says that the target has been properly programmed.
Then, when it tries to switch to debug mode I get this error:
"error: dbg.M0015: Debugger exited unexpectedly during run. Encountered error (Target disconnected See output window for more information."
and the show details tab:
"There was an unhandled error during the debug session. This has forced the debugger to shutdown. Try again."
Even if I try again it does not work at all.
Then I tried with PSoC Creator 3.3 and I am able to debug. Is somebody able to fix that problem on PSoC Creator 4.0?
Regards,
Xavier
