Cypress技术论坛
直播中
李铭冠
8年用户 222经验值
私信 关注
[问答]
PSoC Creator 3.1崩溃然后蓝屏死机
好吧,我?我喜欢使用软件的版本,我知道,我总是试图禁用自动更新。
然而,我发现从PSoC Creator 2.2升级到3.1最近合理。我想是星期五,也许是星期四。我立刻遇到了一个重现性的崩溃。那么今天,我得到一个蓝屏死机和损坏的项目文件,将不再打开。它暂时失去了我的顶级设计和代码编辑。幸运的是,我有每小时自动备份。我能恢复的项目,包括最新的顶层设计的变化(超过一小时),然后复制我的独立的C文件到回收项目,我最近的代码编辑。我只是失去了约2小时,包括启动和其他东西加载状态。
所以我必须找到这个问题的底部,或者回到2.2。
重复出现死机的情况几乎任何**的时候我试图在源代码编辑#宏。这个软件尝试做实时预编译和语法检查,无论你怎么称呼。我相信这是一个问题。如果我试图在#类型包括“文件名。H”,然后出现大跌,100的每一次当我键入“E”完成了“#包括“。我已经附加了错误信息的JPG。而我能型”#如果0“我经常做暂时删除一段代码,我后来当我键入“# endif”得到同样的崩溃,对整理后的单词以字母“F”。
我不知道我在做什么死亡蓝色屏幕时发生。我想,如果再发生这种事,我会担心的。
非常感谢您的帮助。
-赫尔穆特
错误MSG JPG
50.6 K
以上来自于百度翻译
     以下为原文
  Well, me?  I like to stick with the version of software that I know works, and I always try to disable automatic updates.
    Nevertheless, I found it reasonable recently to upgrade from PSoC Creator 2.2 to 3.1.  I think it was Friday; maybe Thursday.  I was immediately met with a reproducible crash.  Then today, I got a blue screen of death and a corrupted project file that would no longer open.  It temporarily lost my top design and code edits.  Fortunately, I have *hourly* automatic backups.  I was able to restore the project, including most recent top design changes (more than an hour old), then copy my free-standing c file back into the project, recovering my recent code edits.  I only lost about 2 hours, including the reboot and reload of other status stuff.
    So I must get to the bottom of this problem, or go back to 2.2.
    The reproducible crash situation occurs pretty much *any* time I try to edit a #macro in the source code.  This software tries to do real-time advance compiling and syntax checking, whatever you call that.  And I believe it is a problem with this and #macros.  If I try to type in  #include "filename.h", then the crash occurs 100% every time when I type the "e" finishing up "#include".  I've attached a jpg of the error message.  While I can type "#if 0" as I often do to temporarily remove a chunk of code, I get the same crash when I later type "#endif", right after finishing the word with the letter "f".
    I don't know exactly what I was doing when the blue screen of death occurred.  I'll worry about that, I guess, if it happens again.
    Your assistance with this is greatly appreciated.
    -Helmut
回帖(6)
王琳
2019-1-16 14:16:17
由于其他电脑不显示这种行为(我只是检查我的)和其他人还宣布了一项类似的问题恐怕原因在您的PC上。
我听说这里的论坛,一个家伙有下载不安装看似有网络问题。我建议你
除安装的创造者3.1、下载安装(於500MB的点)和重新安装的创造者具有管理员权限。
如果你有时间,想这样做,你可以尝试比较下载文件(覆盖旧的-在重命名)你可以得到更多的信息。
鲍勃
以上来自于百度翻译
     以下为原文
  Since other PCs do not show this behave (I just checked mine) and nobody else has yet anounced a similar problem I'm afraid that the cause lies within your PC.
    I have heard here in the forum that one guy had problems with the download which did not install and seemingly had a network problem. I suggest you to
    de-install Creator 3.1, download the installation (bit more than 500MB) and re-install Creator with administrator rights.
    If you have the time and want to do so, you may try to compare the download-files (before overwriting the old one - rename it) you can get some more information.
    Bob
举报
杨军
2019-1-16 14:26:50
MIS系统配置从3.1个发行说明-
以上来自于百度翻译
     以下为原文
  Min sys config from 3.1 release notes -
举报
李铭冠
2019-1-16 14:37:14
谢谢,鲍伯。我的后背口袋里有重新安装的选项。然而,昨天我发现一个项目展示了这个问题,另一个项目却没有。所以我要着手攻克这个项目并把它删掉。我可能会发现对行为负责的特定方面。这也将有助于向论坛提供一个与这方面的项目,SANS公司机密信息,看看它是否确实发生在其他计算机上。
以上来自于百度翻译
     以下为原文
   Thanks, Bob.  I do have the reinstall option in my back pocket.  However, I discovered yesterday that one project exhibits the problem and another doesn't.  So I'm going to take the offending project and strip it down.  I may find a particular aspect that's responsible for the behavior.  That will also tie in to being able to provide to the forum a project with that aspect, sans company confidential info, to see if it does indeed happen on other computers.
举报
王琳
2019-1-16 14:47:15
更好的业余工作和给违规项目与柏权例如我。赛普拉斯将达叻府的所有信息保密,他们有更多的工具来分析这个问题比我们的用户。
鲍勃
以上来自于百度翻译
     以下为原文
  Better spare that work and give the offending project right to Cypress with a MyCase. Cypress will trat all informations as confidential and they have more tools to analyze the issue than we users have.
    Bob
举报
更多回帖
