嗨,我得到消息框“无法启动.NET框架”。
出于某种原因,我需要在双启动系统上安装testexec,因此win7在驱动器D上运行:我必须安装Testexec SL。
(如果我在具有默认安装路径的系统上执行相同的操作,一切正常。)安装后,程序启动属性如下所示:+“D: Program Files Agilent TestExec SL 7.1 Bin tstexcsl.exe”/ Platform“
TestExec SL“/版本7.1 /首选项”D: Users Public Agilent My TxSL Files Test Systems Preferences.upf“+ +”D: Program Files Agilent TestExec SL 7.1 bin“+也是。
.NET Framework安装看起来有点不同,但由Microsoft产品带来:+ - Microsoft .NET Framework 4.5 DEU语言包4.5.50709+ + - Microsoft .NET Framework 4多目标包4.0.30319+ + - Microsoft .NET Framework
4.5 4.5.50709+ + - Microsoft Visual Studio 2010 ADO.NET实体框架工具10.0.40219+ + - TestExec SL + 7.1.1系统上不再有.NET 4.0。
但微软告诉我,.NET4.5完全向后兼容.NET4.0在win7事件日志中,我找不到任何细节。
任何expierience?
亲切的考虑安德烈亚斯系统:在win7 32Bit 8GB上有和没有补丁7.1.3的Testexec 7.1.1
以上来自于谷歌翻译
以下为原文
Hi
I got the messagebox "Unable to start .NET framework".
For some reason, I need to install testexec on a dual boot system, so win7 is running on drive D: an there I have to install Testexec SL. (If I do the same on systems with default installa
tion path, everything works fine.)
After installation, program start properties looks like:
+"D:Program FilesAgilentTestExec SL 7.1Bintstexcsl.exe" /Platform "TestExec SL" /Version 7.1 /Preferences "D:UsersPublicAgilentMy TxSL FilesTest SystemsPreferences.upf"+
+"D:Program FilesAgilentTestExec SL 7.1bin"+
Also the .NET Framework installation looks a little bit different, but brought by microsoft products:
+- Microsoft .NET Framework 4.5 DEU Language Pack 4.5.50709+
+- Microsoft .NET Framework 4 Multi-Targeting Pack 4.0.30319+
+- Microsoft .NET Framework 4.5 4.5.50709+
+- Microsoft Visual Studio 2010 ADO.NET Entity Framework Tools 10.0.40219+
+- TestExec SL+ 7.1.1
There is no .NET 4.0 on the system any more. But microsoft tells, .NET4.5 is fully backwards compatible to .NET4.0
In the win7 eventlog, i can not find any details.
Any expierience ?
Kind regard
Andreas
System: Testexec 7.1.1 with and without Patch 7.1.3 on win7 32Bit 8GB
附件
