Cypress技术论坛
直播中
张龙
7年用户 199经验值
私信 关注
[问答]
AN75779无法查询UVC控件
我正试图建立一个基于AN7799的系统来工作。我在Linux下运行(内核4.12.5)。
当我奔跑
V4L2GAP-MQ 100 D/DEV/VIDO0/O/TMP/GAPP.JPG
当运行V4L2GRAP时,得到以下输出
通过设备/DEV/VIDO0将图像宽度设置为1280。
图像高度由设备/DEV/VIDO0设置为720。
然后它就挂了。
在我的FX3控制台上,我观察到当启动V4L2GRAPH时激活了流
UVC:完成0帧和0缓冲器
UVC:完成0帧和0缓冲器
UVC:完成0帧和0缓冲器
UVC:完成21帧和3缓冲器
UVC:完成42帧和19缓冲器
UVC:完成63帧和35缓冲器
UVC:完成84帧和51缓冲器
UVC:完成106帧和9缓冲器
然而,在Linux主机内核日志中,我观察到:
[7446.534814 ] UVCVID:找到UVC 1设备FX3(04B4:00 F9)
[7446.536477 ] UVCVIEW 2-6:1.0:实体扩展3的实体类型未初始化!
[ 7446.536482 ] uvcvideo 2-6:1.0:实体处理2个实体类型没有被初始化!
[ 7446.536485 ] uvcvideo 2-6:1.0:实体相机1实体类型没有被初始化!
【7446.536654】输入:FX3 /设备/ pci0000:00 / 0000:00:14.0 / USB2 / 2-6 / 2-6: 1.0/input/input13
[ 8488.136849 ] uvcvideo:无法查询(get_def)UVC控制2单元2:1(预期值2)。
什么是错误“无法查询(get_def)引起的UVC控制”?
V4L2Grand工作良好,如果插入一个普通的USB网络摄像头。
以上来自于百度翻译
     以下为原文
  I'm trying to get a system based upon AN75779 to work. I'm running under Linux (kernel 4.12.5).
When I run
v4l2grab -m -q 100 -d /dev/video0 -o /tmp/grab.jpg
When I run v4l2grab I get the following output
Image width set to 1280 by device /dev/video0.
Image height set to 720 by device /dev/video0.
and then it just hangs.
On my FX3 console I observe that streaming is activated when I start v4l2grab
UVC: Completed 0 frames and 0 buffers
UVC: Completed 21 frames and 3 buffers
UVC: Completed 42 frames and 19 buffers
UVC: Completed 63 frames and 35 buffers
UVC: Completed 84 frames and 51 buffers
UVC: Completed 106 frames and 9 buffers
However, in the Linux host kernel log I observe:
[ 7446.534814] uvcvideo: Found UVC 1.00 device FX3 (04b4:00f9)
[ 7446.536477] uvcvideo 2-6:1.0: Entity type for entity Extension 3 was not initialized!
[ 7446.536482] uvcvideo 2-6:1.0: Entity type for entity Processing 2 was not initialized!
[ 7446.536485] uvcvideo 2-6:1.0: Entity type for entity Camera 1 was not initialized!
[ 7446.536654] input: FX3 as /devices/pci0000:00/0000:00:14.0/u***2/2-6/2-6:1.0/input/input13
[ 8488.136849] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: 1 (exp. 2).
What is the error "Failed to query (GET_DEF) UVC control" caused by?
v4l2grab works fine if plug in a plain USB web camera.
回帖(1)
张龙
2019-1-7 14:44:10
V4L2GRAPH挂起是由于格式错误。运行MPER显示,只有一半的预期像素输出:
框架太小!(921600和1843200)格式错误?
在调整YCbCr格式后,M播放现在没有上述运行,V4L2GRAP将完成与抓取的图像。
“失败查询”内核消息仍然存在,但似乎并不致命。
以上来自于百度翻译
     以下为原文
  The v4l2grab hang was due to a format error. Running mplayer revealed that there were only half of the expected pixels being output:
Frame too small! (921600<1843200) Wrong format?
After adjusting the YCbCr format mplayer now runs without the above, and v4l2grab will complete with the grabbed image.
The "Failed to query" kernel message is still there, but it does not seem to be fatal.
举报
更多回帖
