是德科技
直播中
陈琳
8年用户 167经验值
私信 关注
[问答]
用于Command Expert安装失败的Excel加载项
嗨,使用MS Excel 2010在Win7 x64下安装Command Expert(v.1.2 upd.1)我有一个错误消息,告知安装Excel加载项失败。
然后我尝试根据本文中的建议手动安装该加载项。
第二条消息说它能够成功安装加载项。
但是,Excel中没有Command Expert功能区项。
该加载项出现在Excel的加载项列表中,但处于非活动状态,无法激活。
那么有人会提出另一个步骤来让addiin工作吗?
最好的问候,丹尼斯
以上来自于谷歌翻译
     以下为原文
  Hi,
Installing the Command Expert (v.1.2 upd.1) under Win7 x64 with MS Excel 2010 I've got an error meassage informing that installation of the Excel add-in is failed. Then I've tried to install that add-in manually according to recommendations in this post. The second message said that it was able to install the add-in successfully. However there's no Command Expert ribbon item in Excel. That add-in appears in the Excel's add-ins list but in the inactive state and couldn't be activated.
So would anybody suggest another steps to get that addiin working?
Best regards,
  Denis
回帖(4)
杜文渊
2019-1-3 15:40:17
在Excel中,转到“已禁用的插件”列表,然后选择“命令专家”。
你可以重新启用它,或者Excel会给你一个错误信息(如果是,那么错误信息是什么?)
以上来自于谷歌翻译
     以下为原文
  In Excel, go to the list of 'Disabled Addins' and select Command Expert. Can you re-enable it, or does Excel give you an error message (if so, what is the error message?)
举报
陈琳
2019-1-3 15:49:00
重新启用尝试后,Excel会显示以下错误消息:+“未加载。
加载COM加载项“+期间发生运行时错误
以上来自于谷歌翻译
     以下为原文
  After re-enabling attempt Excel gives this error message: +“Not loaded. A runtime error occurred during the loading of the COM Add-In”+
举报
步雅芸
2019-1-3 16:01:08
由于我是使用visual basic的程序员,我只能与[url = http://www.rasteredge.com/how-to/vb-net-imaging/excel-get-to-start/] excel分享你
在vb代码中加载[/ url]方法,用于从本机文件或内存流加载excel doc。
[url = http://www.rasteredge.com/how-to/vb-net-imaging/excel-reading/] excel加载项[/ url]也是我文档图像阅读中最重要的功能之一
和处理库。
因此,如果有人需要关于Excel文档处理的一些讨论,请与我联系。
Private Sub New(filePath As [String])End Sub Private Sub New(sourceStream As Stream)End Sub
以上来自于谷歌翻译
     以下为原文
  As i'm a programmer using visual basic, I can only share you with the excel loading methods in vb code for loading excel doc from native file or from memory stream. The excel add-in is also one of the most important functions of my document image reading and processing library. So, if anyone need some discussions on excel document processing, please contact me.
End Sub
End Sub
举报
陈琳
2019-1-3 16:11:51
嗨艾森豪威尔,我现在已经通过VBA中的VISA COM 3.0类型库获得了对该设备的访问权限。
此致,丹尼斯
以上来自于谷歌翻译
     以下为原文
  Hi Eisenhower,
I have now gained access to the device through VISA COM 3.0 Type Library in VBA w/o Command Expert usage.
Regards,
  Denis
举报
更多回帖
