Cypress技术论坛
直播中
邢待湘
8年用户 170经验值
私信 关注
[问答]
PSoC Creator中的Ghost组件
我在PSoC Creator身上有一个非常奇怪的问题。
我在我的TopDead示意图中放置了一个DeunCube组件“DeBuntEXCRSTX”。后来,我删除了这个组件。当我尝试构建时,我得到了:
错误1-6指的是我删除的东西。
因此,我删除了PopDebug .CysCH文件,从Git存储库中获取旧的文件。同样的错误。然后我删除每一个生成的文件,然后重试。同样的事情。这没有任何意义…这个组件和相关的网络只在这个项目中只有大约十分钟的今天上午,但是,它们似乎是永久的。这是系统中一个非常严重的错误。我的形象,我可以完全重新创建项目,让这些不再出现,但这是不必要的。
完整项目的屏幕截图已附上。不要介意C代码错误,而不是问题。
PNC创建者
545.5 K
以上来自于百度翻译
     以下为原文
  I'm having a very weird problem in PSoC Creator.
I had placed a Debouncer component, "Debounced_CRSTX" in my TopDesign schematic. Later, I deleted that component. When I try to build, I get this:
Errors 1-6 refer to things that I deleted.
So I delete the TopDesign.cysch file, get the old one from my GIT repository. Same error. Then I delete every generated file, and try again. Same thing. This doesn't make any sense... this component and the associated nets were only in this project for about ten minutes this morning, and yet, they seem permanent. This is a pretty serious bug in the system. I image I can completely re-create the project an have these not appear any longer, but that should not be necessary.
Screen shot of the full project is attached. Never mind the C-code errors, not the problem.
回帖(7)
王琳
2019-1-3 14:41:12
你使用的是哪个版本的创建者?能否请您发布您的完整项目,以便我们都可以看看您的所有设置。为此,使用
创建者-gt;文件& gt;创建工作区束(最小)
并附加生成的文件。
鲍勃
以上来自于百度翻译
     以下为原文
  Which version of Creator are you using? Can you please post your complete project so that we all can have a look at all of your settings. To do so, use
Creator->File->Create Workspace Bundle (minimal)
and attach the resulting file.
Bob
举报
邢待湘
2019-1-3 14:49:44
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
朱寅竹
2019-1-3 15:05:05
我在PSoC创建者4.1上的项目也有同样的问题。
软件中有一些bug。这些错误并不是真正的错误,因为项目正常编译(当您查看输出选项卡时,您会看到编译完成没有错误)。使它们消失的方法是关闭造物主并再次打开它。
这很烦人。
以上来自于百度翻译
     以下为原文
  I have the same problem with my projects on PSoC Creator 4.1.
There is some kind of bug in the software. These errors are not really errors, because the project compiles normally (when you look at the Output tab, you see that the compilation finishes without errors). The way to make them disappear is to close the Creator and open it again.
This is very annoying.
举报
邢待湘
2019-1-3 15:22:17
实际上,我看到的错误版本在重置创建者或重新启动Windows之后没有消失。如果编译的代码与否,实际上也不重要——如果编译器出错,我不能相信编译器会做正确的事情,这违反了我为我们的硬件组制定的任何类型的错误发布的策略。
但是,恢复原始项目文件确实删除了错误。所以当我在示意编辑器中工作时,我会把东西推得很整齐,以防万一它再次出现。
以上来自于百度翻译
     以下为原文
  Actually, the version of the error I have seen didn't disappear after resetting either Creator or rebooting Windows. It also wouldn't actually matter if the code compiled or not -- I can't trust the compiler to do the right thing if it's producing errors, and it's against the policies I set for our hardware group to do any kind of release with errors of any kind.
However, restoring one's original project file did remove the error. So I'm pushing stuff to GIT pretty regularly when working in the schematic editor, just in case it shows up again.
举报
更多回帖
