Microchip
直播中
林俭幼
8年用户 151经验值
私信 关注
[问答]
IPE v4.01不会对dsPIC30F6015进行编程
为什么IPE V4.01不编程我的DSPIC30F6015?这里是IPE错误和我的DSPIC配置。还有其他的信息我应该提供吗?感谢您的任何建议。IPE错误:您正在尝试更改保护启动和安全内存。为了做到这一点,您必须在调试工具安全段属性页上选择“启动、安全和通用段”选项。f,McRe= McRrEn.PrimaMac配置,BWRP= WRYPrimeTuxBoToOXON-PractMaMig-COMPIG配置,SWRP= WrpPrimeSeCixonα-PrimaMig-COFIG GWRP= GWRPp*,在πPrimaMac配置ICS=ICSU-PGD上
以上来自于百度翻译
      以下为原文
    Why will the IPE v4.01 not program my dsPIC30F6015?
Here is the IPE error and my dsPIC config.
Is there some other information I should provide?
Thanks for any advice.
IPE error:
You are trying to change protected boot and secure memory. In order to do this you must select the "Boot, Secure and General Segments" option on the debug tool Secure Segment properties page.
Failed to program device.
My config:
#pragma config FOSFPR = HS2_PLL16, FCKSMEN = CSW_FSCM_OFF
#pragma config WDT = WDT_OFF
#pragma config FPWRT = PWRT_16, BOREN = PBOR_OFF, MCLRE = MCLR_EN
#pragma config BWRP = WR_PROTECT_BOOT_ON
#pragma config SWRP = WR_PROT_SEC_ON
#pragma config GWRP = GWRP_ON
#pragma config ICS = ICS_PGD
回帖(2)
陈珂瑾
2018-12-29 16:24:16
在IPE中的设置类别下,可以在安全段下选择一个选项。我认为您应该选择“引导、安全和一般段”,以便继续对设备进行编程。
以上来自于百度翻译
      以下为原文
    Under Settings category in IPE there's an option under Secure Segment that can be selected.
I think you should select "Boot, Secure and General Segments" in order to proceed with programming the device.
举报
张娜
2018-12-29 16:42:14
SETHIPP//www. McCHIP.COM/FUMMS/M1019645.ASPX
以上来自于百度翻译
      以下为原文
    see
http://www.microchip.com/forums/m1019645.aspx
举报
更多回帖
