TI论坛
直播中
王帅
8年用户 226经验值
私信 关注
[问答]
调试EVM板Core0无法运行
调试EVM板过程中遇到连接问题,Core0无法运行。显示如下:
DEBUG过程图像:
显示信息:
C66xx_0: GEL Output: Setup_Memory_Map...
C66xx_0: GEL Output: Setup_Memory_Map... Done.
Connecting Target...
C66xx_0: GEL: Error while executing OnTargetConnect(): identifier not found: DNUM.
C66xx_0: GEL Output: Invalidate All Cache...
C66xx_0: GEL Output: Invalidate All Cache... Done.
C66xx_0: GEL: Error calling OnPreFileLoaded(): identifier not found: IER
C66xx_0: GEL: Error while executing OnRestart(0): identifier not found: DNUM.
C66xx_0: GEL: Error while executing OnFileLoaded(0, 0): identifier not found: DNUM.
C66xx_1: The callstack was unable to find Frame Pointer register information
C66xx_2: The callstack was unable to find Frame Pointer register information
C66xx_3: The callstack was unable to find Frame Pointer register information
C66xx_4: The callstack was unable to find Frame Pointer register information
C66xx_5: The callstack was unable to find Frame Pointer register information
C66xx_6: The callstack was unable to find Frame Pointer register information
C66xx_7: The callstack was unable to find Frame Pointer register information
在其他核中运行单步调试,显示:
ccxml以及cmd文件见附件
请问各位专家这是什么问题呢?
回帖(17)
孙榕
2018-12-26 14:20:47
你好,
你的ccxml文件在我的ccs中报错,你在你的工程中尝试下附件中的cmd和ccxml文件,如有问题,请继续跟贴!
举报
王帅
2018-12-26 14:33:06
补充一下,使用的仿真器为SEED-XDS560V2,板子为TMDXVEM6678LE  Rev1.0
举报
孙榕
2018-12-26 14:51:45
你好,
这个贴,也有参考价值
www.deyisupport.com/.../11172.aspx
举报
王帅
2018-12-26 15:03:38
引用: hfjydz2013 发表于 2018-12-26 09:26
你好,
您好!
您的压缩文件里面没有内容啊,请问是不是放错了?
举报
更多回帖
