> {quote:title = glemire写道:} {quote}>你好,>> 1)我的DUT传输波形的振幅约为1V pp。一般情况下,你建议在测量具有此度数的有源设备时使用衰减器。
>大约7 dBm,应该没问题。
> 2)我的IF_BW设置为大约1kohm。
我正以10 MHz的步幅从10MHz-18GHz扫描。
这似乎是一个合理的值,但你建议使用i)平均,ii)平滑和iii)不同的IF_BW设置?
你可能意味着1kHz,而不是kohm。
除非你在测量中看到太多的噪音,否则我会推荐它。
> 3)我注意到当我减小IF_BW时,扫描需要更长的时间。
根据我的理解,减少IF_BW将减少随机噪声并降低我的本底噪声,但我不确定为什么扫描需要更长时间。
我假设IF滤波器正好位于接收器中的ADC之前。
测量采集时间为1 / BW,因此1kHz表示每点1毫秒测量。
使IF BW更小使得测量时间成比例地更长。
> 4)进行此类热测量时,您可以推荐什么?
这些热测量有点棘手。
S11始终是热测量,但通常在S22测量期间,端口1上的源关闭。
您可以联系当地的安捷伦应用工程师以获得更多信息,因为详细信息有点难以通过论坛提供。
以上来自于谷歌翻译
以下为原文
> {quote:title=glemire wrote:}{quote}
> hello,
> 1) the amplitude of my DUT transmitted waveform is about 1V pp. In general do you recommend using attenuators when measuring an active device with this ampitude.
That's roughly 7 dBm, should be OK.
> 2) I have my IF_BW set to be about 1kohm. I am sweeping from 10MHz-18GHz in 10 MHz steps. This seems to be a reasonable value, but do you recommend using i) averaging, ii) smoothing and iii) differant IF_BW setting?
You probably mean 1kHz, not kohm. It is what I would recommend unless you see too much noise in the measurement.
> 3) I notice that when I reduce the IF_BW, the sweep takes a longer time. From what i understand reducing the IF_BW will reduce the random noise and lower my noise floor, but I am not sure why the sweep would take longer. I assume the IF filter is right before the ADCs in the receiver.
The measurement acquisition time is 1/BW, so 1kHz means 1 msec measurement per point. Making the IF BW smaller makes the measurement time proportionately longer.
> 4) anything elsethat you can recommend when doing this type of a hot measurement?
These hot measurements are a little tricky. S11 is always a hot measurement, but usually during the S22 measurement, the source on port 1 is turned off.
You might contact your local Agilent Application Engineer to get more insight, as the details are bit hard to give over the forum.
>大约7 dBm,应该没问题。
你可能意味着1kHz,而不是kohm。
> 4)进行此类热测量时,您可以推荐什么?
这些热测量有点棘手。
以上来自于谷歌翻译
以下为原文
> hello,
举报
