Microchip
直播中
刘桂兰
8年用户 1047经验值
私信 关注
[问答]
无法选择Curiosity board作为编程工具
过去我用MPLABX使用好奇心板,没有问题。然而,我刚刚插入了新的HPC板,我不能选择好奇心板作为一种编程工具。它会出现在选项中(没有序列号,但“好奇”弹出),但我在物理上无法点击它。当我拔出板时,使用好奇板的选项将在MPLABX中消失,所以我知道它正在看板。见附图PictReSun-MPLABX,启动一个新项目& GT;独立项目& GT;选择一个设备& GT;&在“微芯片起动器工具包”下面看好奇心板应该在哪里。这是我粘贴的屏幕。这是我的MPLABX产品版本的信息:MPLAB X IDE V4.05Java:1.8 0144;Java热点(TM)64位服务器VM 25.144-B01Runtime:Java(TM)SE运行时环境1.80y144-B01Stase:Windows 10版本10在AMD64上运行;CP1252;EN(MPLAB)
以上来自于百度翻译
      以下为原文
    I've used the Curiosity board with MPLABX in the past with no problems.  However, with the new HPC board I just plugged in I can't select the Curiosity board as a programming tool.  It will show up in the options (no serial # but 'Curiosity' pops up) but I physically cannot click on it.  When I unplug the board the option for using the Curiosity board will go away in MPLABX so I know it's seeing the board.  See attached pictures
Open MPLABX, start a new project>>stand alone project>>pick a device>>look under the 'Microchip Starter Kits' where the Curiosity board should be.  This is the screen I'm stuck on.
Here's the info on my version of MPLABX
Product Version: MPLAB X IDE v4.05
Java: 1.8.0_144; Java HotSpot(TM) 64-Bit Server VM 25.144-b01
Runtime: Java(TM) SE Runtime Environment 1.8.0_144-b01
System: Windows 10 version 10.0 running on amd64; Cp1252; en (mplab)
   Attached Image(s)
回帖(12)
杨叶
2018-12-13 16:46:55
嗨,工具是红色的。它可能意味着你选择了一个不受好奇心HPC板支持的图片。你选择了哪一个PIC?当做
以上来自于百度翻译
      以下为原文
    Hi,
the tool is red. It probably means you selected a PIC which is not supported by the Curiosity HPC board.
Which PIC have you selected?
Regards
举报
李红
2018-12-13 17:03:58
PIC18F26K42
以上来自于百度翻译
      以下为原文
    PIC18F26K42
举报
杨叶
2018-12-13 17:14:52
嗨,我已经成功地使用了PIC18F47 K40,但是K42家族可能太近了。希望它将来会得到支持。我用好奇心板来进行快速原型制作,也因为它很容易添加点击板。
以上来自于百度翻译
      以下为原文
    Hi,
I have used PIC18F47K40 successfully but probably the K42 family is too recent...
Hopefully it will be supported in the future.
I use curiosity boards for quick prototyping and also because it is easy to add click boards.
Regards
举报
杨叶
2018-12-13 17:19:59
嗨,我试了好奇心HPC上的PIC18F25K42,它工作得很好。我很惊讶PIC18F26K42不支持iPIC18F25K42支持:MPLAB X V4.05MCC插件V3.36XC8V1.44
以上来自于百度翻译
      以下为原文
    Hi,
I just tried PIC18F25K42 on Curiosity HPC and it works fine.
I would be surprised that PIC18F26K42 is not supported if PIC18F25K42 is supported
I use :
MPLAB X v4.05
MCC plugin v3.36
XC8 v1.44
Regards
举报
更多回帖
