你好,
1.在Xilinx产品许可站点的“创建新许可证”选项卡中检查许可证是否可用。
2.如果仍然无法找到,请填写此表格,与订单详细信息联系我们的客户服务:http://www.xilinx.com/askx/customer_service_form.htm
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hello,
1. Check whether the license is available in the "Create New Licenses" tab of Xilinx Product Licensing Site.
2. If you still can't find it, contact our customer service with order details by filling this form: http://www.xilinx.com/askx/customer_service_form.htm
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
你好,
谢谢,
维奈
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hello,
Thanks,
Vinay
举报
