你好Jackos,这听起来像是一个非常合理的测量,应该没有错误,但我们不能仅仅从那个描述中诊断它。
我建议联系eesof_support@agilent.com并将* .mdl文件与您的设置以及* .hdw文件一起发送(执行文件>保存硬件窗口)。
要检查的内容是设置输入和输出中的SMU单元名称。
确保在安装程序中引用的内容与硬件窗口中4155的单元名称相匹配。
例如
转到硬件窗口,选择4155并单击配置以检查单元名称。还要检查SMU类型。
如果您没有看到问题,最好将问题发送到eesof_support@agilent.com(带* .mdl和* .hdw),然后我们将很乐意进一步检查。
最好的问候,其他
以上来自于谷歌翻译
以下为原文
Hello Jackos,
That sounds like a very reasonable measurement to be doing and should run without that error, but we cannot diagnose it just from that description. I suggest to contact eesof_support@agilent.com and send the *.mdl file with your setup, as well as the *.hdw file (do File > Save off the Hardware window). The things to check would be the SMU Unit Names in the Setup Inputs and Outputs. Make sure what you refer to in the Setup matches your Unit Names for the 4155 in the Hardware window. e.g. Go to Hardware Window, select the 4155 and click on Configure to check the Unit Names.Also check the SMU types. If you do not see a problem by doing that, the best would be to send the problem to eesof_support@agilent.com (with *.mdl and *.hdw) and then we will be happy to check into it further.
Best regards,
Else
例如
最好的问候,其他
以上来自于谷歌翻译
以下为原文
Hello Jackos,
Best regards,
Else
举报
