亲爱的MattC,我确实可以使用这个附加命令来直接了解任何安捷伦电源输出端的电压,并了解传感线发送时的电压。
我会用这些信息来了解一下连接的可靠性。
在进行测量并使用(V_output - V_sense)/ Current计算电阻时,该值应保持不变(如果电流不改变数十年)。
然后,当人们看到变化的电阻值时,这表明线路的可靠性受到威胁。
以上来自于谷歌翻译
以下为原文
Dear MattC, I do have a usage for this additional command to know the voltage directly at the outputs of any Agilent power supply and to know the voltage at the send of the sense lines.
I would use this information to know a bit about the reliability of the connections. When doing measurements and calculating a resistance by using (V_output - V_sense) / Current, this value should remain constant (if the current does not change decades). Then when one sees a changing resistance value this indicates that the lines' reliability is at stake.
我会用这些信息来了解一下连接的可靠性。
以上来自于谷歌翻译
以下为原文
举报
