我试图在FX3和主机之间创建一个大容量的数据通道。输入到FX3的数据由
FPGA馈送。我非常使用SLaveFIFO应用程序(AN6997)作为参考,但是修改了以下内容:1)FPGA和FX3之间的数据通道是16位宽的。
与往常一样,Windows将FX3识别为引导加载设备,控制中心也是如此。然而,在编程之后,我在任何地方都看不到设备。附件中有问题的截图。
提前感谢。
高压
枚举错误20171113DOX
280 K
以上来自于百度翻译
以下为原文
I'm trying to create a bulk data channel between the FX3 and host. The data input to the FX3 is fed by an FPGA. I have pretty much used the slavefifo applica
tion(AN65974) as the reference but modified the following : 1)The data channel between the FPGA and FX3 is 16 bits wide.
As usual,windows recognizes the FX3 as a bootloader device and so does the control center. However, after programming, I do not see the device anywhere. The enclosed document has screenshots of the problem.
Thanks in advance.
HV
