ST意法半导体
直播中
李方树
8年用户 172经验值
私信 关注
[问答]
LIS3DH加速度计自我测试失败
我们有一个LIS3DH加速度计,最终处于闩锁状态。输出数据为-205 / -1149 / -4759(X / Y / Z,mg)。当进行自测试时,2个样品之间的绝对差异是7/6/3(X / Y / Z,以mg计),其远低于最小限度(> 60mg)。有没有办法从中恢复?我是否必须使加速度计无能为力?
#闭锁
以上来自于谷歌翻译
以下为原文
We have a LIS3DH accelerometer that have ended up in a latch-up state. The output data is -205/-1149/-4759 (X/Y/Z in mg). When performing the self test, the absolute difference between the 2 samples are 7/6/3 (X/Y/Z in mg) which is well below the min limit (> 60mg). Is there any way to recover from this? Do I have to make the accelerometer powerless?
#latch-up
回帖(1)
陆英史
2018-12-3 09:52:34
我使用LSM303D,有时会在所有轴上出现最大数据状态。
断电,重置ecc。不要唤醒加速度计。
一种解决方案是多次强烈冲击/碰撞,加速度计再次开始运行。
这确实是一个问题......我们不知道如何解决它。
这似乎是一个类似于你的问题。
以上来自于谷歌翻译
以下为原文
I use LSM303D and sometime falling in an state of maximum data out on all axis.
Power down, reset ecc. not wake the accelerometer.
The one solution is a strong shock/crash several times and the accelerometer starts running again.
This is really a problem ... and we do not know how to solve it.
It seems a problem similar to yours.
举报
更多回帖
