英特尔
直播中
李倩
7年用户 242经验值
私信 关注
[问答]
英特尔SR300 Razer Stargazer无法与OBS合作
最近购买了Razer Stargazer,现在才意识到这些产品已经得到了很多支持。
让相机正常工作,在xsplit和所有其他程序中工作得很好但是,位于OBS的intel真实插件无法正常工作.https://gyazo.com/4132ea0c25daa38f5cbbdc7d65c31bb8
屏幕截图 - 4132ea0c25daa38f5cbbdc7d65c31bb8 - Gyazo
我联系过OBS,他们告诉我个人问你们英特尔,因为你们显然为他们编写了这个插件并且他们不知道。
同样令人沮丧的是,发现intels网站上列出的很多程序都是404错误,不再支持intel realsense。
Razer似乎已经完全否认了这个产品,将其从网站上删除并且没有回复支持票。
所以,如果您不知道为什么OBS可能会失败,您可能会推荐一个支持intels realsense的应用程序或程序,以便它可以与OBS一起使用。
正如香港专业教育学院所说,xsplit真实相机工作正常,但我讨厌xsplit,更多的是OBS粉丝,所以是的。
请帮帮我
以上来自于谷歌翻译
以下为原文
Recently purchased the Razer Stargazer and just realising now that there isnt much support anymore for these sorts of products. Got the camera working in general, the realsense is working fine in xsplit and all other programs however, the intel real-sense plugin located in OBS fails to function.https://gyazo.com/4132ea0c25daa38f5cbbdc7d65c31bb8
Screen capture - 4132ea0c25daa38f5cbbdc7d65c31bb8 - Gyazo
Ive contacted OBS, they told me to personally ask you guys at intel as you apparently coded the plugin for them and they have no idea. Its also slightly frustrating to find that a lot of the programs listed on intels website are all 404 errors and no longer support intel realsense. Razer seems to have fully disowned this product by removing it from their website and failing to reply to support tickets. So, if you dont know why OBS might be failing could you perhaps recommend a application or program that will support intels realsense so it will work with OBS. As ive said, xsplit the realsense camera works fine but i hate xsplit and am more of an OBS Fan, so yea. Help me please
回帖(11)
卿洁
2018-12-3 15:53:51
Razer Stargazer通常适用于与SR300配合使用的应用程序。
然而,Razer确实在OBS的绿屏功能方面存在问题。
https://obsproject.com/forum/threads/stargazer-realsense-green-screen-not-working.65913/
下面链接的文章建议如何使用任何相机而不是RealSense软件专门在OBS中进行绿屏。
https://www.windowscentral.com/how-use-green-screen-obs-and-xsplit
SR300现在已经退役,虽然它继续在这个帮助论坛上得到技术建议(尽管不是新的驱动程序更新)的支持,就像之前的所有RealSense型号一样。
SR300与当前的RealSense SDK 2.0软件兼容。
发布·IntelRealSense / librealsense·GitHub
以上来自于谷歌翻译
以下为原文
The Razer Stargazer usually works fine with applications that work with SR300.  However, the Razer does seem to have problems with OBS' green-screen function.
The article linked below suggests how to green-screen in OBS using any camera, rather than the RealSense software specifically.
SR300 is now a retired product, though it continues to be supported on this help forum with tech advice (though not new driver updates), as are all previous RealSense models.  SR300 is compatible with the current RealSense SDK 2.0 software.
Releases · IntelRealSense/librealsense · GitHub
举报
李倩
2018-12-3 16:02:01
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
卿洁
2018-12-3 16:18:42
引用: cmh13 发表于 2018-12-3 07:16
我购买网络摄像头的全部原因是为了避免使用绿屏哈哈,所以这不是一个真正的选择。
Razer将它宣传为与OBS合作,然后当它真的没有时,这真是一种耻辱....似乎我只是浪费了400美元甚至没有工作的东西。
亚马逊甚至都不给我退款,这太棒了。
我有点困惑。
你说你想避免在OBS中使用绿屏,但是你从菜单中选择了绿屏选项。
如果您只想要RGB视频,可以使用Display Capture或Video Capture Device等选项。
以上来自于谷歌翻译
以下为原文
I am a little confused.  You said that you wanted to avoid using green-screen in OBS, but you are selecting the green-screen option from the menu.  If you just want the RGB video, an option such as Display Capture or Video Capture Device might work better.
举报
卿洁
2018-12-3 16:28:32
引用: nywerwer 发表于 2018-12-3 07:33
我有点困惑。
我不知道过去与涉及Razer Stargazer的SR300兼容应用程序不兼容的情况。
它通常作为SR300相机完全可靠。
如果您刚购买了Razer,可以尝试使用SR300深度相机管理器程序将驱动程序和相机的内部“固件”更新为可用的最终版本。
可以使用以下链接在浏览器中下载深度摄像机管理器程序。
https://downloadmirror.intel.com/25044/eng/intel_rs_dcm_sr300_3.3.27.5718.exe
以上来自于谷歌翻译
以下为原文
I'm not aware of any past cases of incompatibilities with SR300-compatible applications that involve the Razer Stargazer.  It has usually been fully reliable as an SR300 camera.
If you have just bought your Razer, you could try using the SR300 Depth Camera Manager program to update the drivers and the camera's internal 'firmware' to the final version that was available.  The Depth Camera Manager program can be downloaded in your browser using the link below.
举报
更多回帖
