您是否在操作工具箱时查阅了CY8CKIT 037 PSoC 4电机控制评估工具包指南PDF?
具体来说,确保USB电缆的另一端在这个步骤中连接到PC,否则,电机将不会开始旋转。按下SW2按钮启动电机旋转(参见图5-14)。如果电机不旋转,并且观察到LED 2闪烁,则发生错误。如果是,首先检查步骤1到步骤5是否正确执行。然后按下复位按钮并再次按下SW2按钮。如果LeD2仍然闪烁,硬件或软件一定会出现问题。
以上来自于百度翻译
以下为原文
Have you been referred to the
CY8CKIT 037 PSoC 4 Motor Control Evaluation Kit Guide.pdf when operating the kit?
Specifically, Ensure that the other end of the USB cable is connected to the PC in this step; otherwise, the motor will not start rotating. Press the SW2 button to start motor rotation (refer to Figure 5-14). If the motor does not rotate and you observe LED2 blinking, an error has occurred. If so, first check that step 1 through step 5 have executed correctly. Then press the Reset button and press the SW2 button again. If LED2 still blinks, there must be a problem in the hardware or software.
以上来自于百度翻译
以下为原文
举报
