ST意法半导体
直播中
张倩
8年用户 198经验值
私信 关注
[问答]
LIS3DH不输出任何X数据
嗨,
由于某种原因,X通道无法正常工作。
以下是每个配置寄存器的配置:
send [0] = 0b01100000; //启动配置
发送[1] = 0x57; // reg 1
发送[2] = 0x00; // reg 2
发送[3] = 0x00; // reg 3
发送[4] = 0x88; // reg 4
send [5] = 0x00; // reg 5
发送[6] = 0x00; // reg 6
显然,只需简单地获取数据,所有导入实际上都在寄存器1中,但我的X输出始终是-32624(这是有符号值)
如果有人知道会出现什么问题,那就太好了。
谢谢,
阮经天
以上来自于谷歌翻译
以下为原文
Hi,
For some reason, the X channel is not working.
Here are my configurations for each config register:
send[0] = 0b01100000;//start config
send[1] = 0x57;//reg 1
send[2] = 0x00;//reg 2
send[3] = 0x00;//reg 3
send[4] = 0x88;//reg 4
send[5] = 0x00;//reg 5
send[6] = 0x00;//reg 6
Clearly everything import is really in register 1 for just simple getting data out, but my X output is always -32624 (that's the signed value)
If anyone knows what could be going wrong, that would be great.
Thanks,
Ethan
回帖(1)
孙海燕
2018-11-26 10:38:52
嗨,
 你能读出WHO_AM_I注册吗?您是否根据数据表阅读了正确的值?
 RGDS
 V.
以上来自于谷歌翻译
以下为原文
Hi,
can you read out the WHO_AM_I register ? Do you read correct value according the datasheet?
Rgds
V.
举报
更多回帖
