英特尔
直播中
贾伟刚
8年用户 1676经验值
私信 关注
[问答]
需要有关SSD离线的帮助以及无法解决的元数据错误
我买了一台安装了英特尔快速存储技术的二手HP Envy 750-624 ...... SSD显示离线,13gb的元数据可能有问题......当我尝试清除metadat时出现错误0xA00000AA - 未知错误
在操作正在进行时发生。
操作无法完成。
我无法访问SSD并且不知道从哪里开始....我买了这个希望SSD启动系统并让HD只存储信息....当我启动时我收到警告通知
系统......我希望它能起作用......我该怎么办?
以上来自于谷歌翻译
以下为原文
I bought a used HP Envy 750-624 that has Intel Rapid Storage Technology installed... the SSD shows to be Offline with 13gb of metadata potentially a problem...  when I try to clear the metadat I get error 0xA00000AA - an unknown error occured while an operation was in progress. The operation could not be completed.  I can't access the SSD and have no idea where to start.... I bought this hoping for the SSD to startup the system and let the HD just store info.... I get a warning notice when I start up the system... I'd like it to work ... what should I do?
回帖(12)
汤宇
2018-11-26 14:35:43
HelloApril418,我知道你现在遇到SSD的问题,因为它显示为离线。我想先问一下,SSD的型号是什么?
另外,请向我提供英特尔®系统支持实用程序报告,该报告可以从我们的工具生成,您可以参考下面的链接,以便下载它:https://downloadcenter.intel.com/download/25293/
Intel-System-Support-Utility-for-Windows-确保将创建的报告附加到此主题。一旦我们获得此信息,我们将能够进一步帮助您进行查询.Regards,David V
以上来自于谷歌翻译
以下为原文
Hello April418,
I understand that you are currently experiencing problems with the SSD since it shows as offline.
I would like to start by asking, what is the model of the SSD? Also, please provide me with an Intel ® System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Make sure to attach the created report to this thread.
Once we have this information we will be able to assist you further with your inquiry.
Regards,
David V
举报
李玉鑫
2018-11-26 14:44:47
Intel-System-Support-Utility-for-Windows-确保将创 ...
大卫嗨....我已经附上了报告....摘要和详细版本....根据英特尔驱动程序&
我在2天前生成的Support Assistant报告,我的SSD显示为:NVMe INTEL MEMPEK1W01,容量为0.00 GB,固件版本0310,序列号PHBT72730A40016D_00000001,0分区,Microsoft驱动程序版本10.0.17134.1,驱动程序日期为6/21/2006
...我也有设备ID ....
我对此很陌生,但我希望我们能让它发挥作用......
谢谢!
四月D.
April418_20180824_System支持实用程序Report_Detailed.txt.zip
22.4 K.
20180824_April418_System支持实用程序Report.txt.zip
22.4 K.
以上来自于谷歌翻译
以下为原文
Hi David.... I've attached the report.... the summary and detailed versions....  per the Intel Driver & Support Assistant report that I generated 2 days ago, my SSD  shows up as: NVMe INTEL MEMPEK1W01 with 0.00 GB Capacity, Firmware Version 0310, Serial Number PHBT72730A40016D_00000001, 0 Partitions, Microsoft Driver Version 10.0.17134.1 with a 6/21/2006 Driver Date ...  I have the Device ID also....
I'm pretty new to this, but I'm hoping we can make it work....
Thanks!
April D.
举报
汤宇
2018-11-26 14:55:17
...我也有设备ID ....
HelloApril418,感谢您的回复。我目前正在审核报告中的信息。
谢谢,与此同时,我想了解更多有关问题的信息。
这是SSD本身的问题还是您遇到英特尔®快速存储技术问题?换句话说,您是否能够正确使用SSD?
例如:如果你去你的系统,你能看到它吗?
你能访问它吗?请让我知道。大卫V.
以上来自于谷歌翻译
以下为原文
Hello April418,
Thank you for your response.
I am currently reviewing the information in the report. Thank you, in the meantime however, I would like to have more information of the problem. Is this a problem of the SSD itself or are you having a problem with Intel ® Rapid Storage Technology?
In other words, are you able to use the SSD properly? For example: If you go to your system, are you able to see it there? Are you able to access it?
Please let me know.
Regards,
David V
举报
贾伟刚
2018-11-26 15:03:11
大卫嗨....感谢您的回复....因为这是我第一次使用快速存储技术和带有SSD的CPU,也许我的答案都是....每次我启动计算机时,我都会得到一个IAStorlcon
通知告诉我“英特尔快速存储技术 - 您的系统正在报告一个或多个警告和数据可能存在风险。打开应用程序以获取详细信息”当我打开应用程序时,我的SATA磁盘有绿色检查,但PCle SSD有一个
警告...当前状态将我发送到管理区域,用于“控制器1上的PCle SSD,端口0:离线(在蓝色文本中用下划线表示)清除元数据在存储系统视图上,它将SSD显示为
13 GB(因为它大于此而让我感到困惑)。当我点击清除元数据时,我会收到警告,要求在继续之前备份数据,清除元数据将永久删除该磁盘上的所有现有数据。确定要
继续。我单击是并获得带有红色X和(0xA00000)的IRST框
AA):操作正在进行时发生未知错误。
操作无法完成。
我所能做的只是关闭方框。
我不明白为什么存储视图将SSD显示为13GB,但报告显示0 ....我不知道如何进行脱机状态更改。
所以我希望我已经足够回答了你的问题所以你可以提供帮助......我确实已经加载了Team Viewer,如果这有帮助的话。
四月
以上来自于谷歌翻译
以下为原文
Hi David....  Thanks for your response.... since this is my first adventure with Rapid Storage Technology and a CPU with a SSD maybe my answer is both.... everytime I start up my computer, I get an IAStorlcon notification telling me that "Intel Rapid Storage Technology - Your system is reporting one or more warnings and data may be at risk.  Open the application for details"   when I open the application my SATA disk has a green check, but the PCle SSD has a warning... as does the Current Status which is sending me to the Manage area for the "PCle SSD on Controller 1, Port 0: Offline (underlined in blue text it says) Clear metadata   On the Storage System View it shows the SSD as 13 GB (which confuses me since it is larger than that).   When I click on the Clear metadata I get a warning to back up data before continuing and Clearing metadata will permanently delete any existing data on that disk.  Are you sure you want to continue.  I click YES  and get the IRST box with a red X and the (0xA00000AA): An unknown error occurred while an operation was in progress.  The operation could not be completed.  All I can do is Close the box.   I do not understand why the storage view shows the SSD as 13GB, but the report says 0.... I don't know how to make the Offline status change.  so I hope I've answered your questions enough so you can help....  I do have Team Viewer loaded, if that helps at all.   April
举报
更多回帖
