嗨,我正在尝试使用excel表作为“配置表”,其中包含我在VEE中运行的程序的配置数据。
我已经让VEE程序打开相应的excel表并以2D数组的形式读取数据。
获取这些数据并使用单个数据填充许多不同“设置变量”的最简单方法是什么?
(约20个不同的值,即:最小时间最大时间最小温度最大温度最小电压最大电压最小电流......等等)提前感谢您的帮助!
以上来自于谷歌翻译
以下为原文
Hi,
I'm trying to use an excel sheet as a "configura
tion sheet" that has configuration data for the program I'm running in VEE.
I already have the VEE program opening the appropriate excel sheet and reading the data in as a 2D array.
What is the easiest way to take this array of data and populate many different "set variables" with individual data?
(about 20 different values i.e.:
min time
max time
min temp
max temp
min voltage
max voltage
min current
... etc.)
Thanks in advance for your help!
