Microchip
直播中
李锰
7年用户 181经验值
私信 关注
[问答]
Picdem net 2开发板WEB页面
亲爱的朋友们!我有一个我无法解决的问题。我在我的PDENM网2 DEV板上获得了APIC18F97 J60芯片。我使用了来自2013MLA的Microchip的WebVeDo演示应用程序。我遵循了我在演示文稿网上找到的步骤,我得到了这个结果。我尝试从我的结果中附加图像。演示链接:(http://www. McCys.com / SteleNo/组/ SITECOMMSOSG/Debug)/DEVICEDC/ON53030.pdf)我希望有人能帮助我。我还附上一个TXT文件,里面有我的代码。如果你需要更多的信息,请告诉我。
以上来自于百度翻译
      以下为原文
    Dear forumers!
I have a problem that i can't solve. I got a PIC18F97J60 chip in my PICDEM NET 2 dev board. I used a WEBVEND demo app from microchip from the 2013MLA. I followed the steps that i found online in a presentation , and i get that result . I try to attach images from my result.
The presentation link:( http://www.microchip.com/stellent/groups/SiteComm_sg/documents/DeviceDoc/en543038.pdf )
I hope someone can help me. And i also attach a txt file with my code in it for the page. If you need any more information let me know.
   Attached Image(s)
Attachment(s)
kod.txt (2.27 KB) - downloaded 52 times
回帖(2)
李广旭
2018-11-15 14:42:08
这是默认的回调函数,这是我们在文本框中看到的。但是如果我给文本框写了一些东西,然后保存它。它得到了液晶显示屏和它的可见,但在那个时候,Web浏览器刷新自己,数据我写到文本框已经不见了。
以上来自于百度翻译
      以下为原文
    This is the default callback function and that is what we see in the text boxes. But if i write something to the text box, and save it. Its get sended to the LCD screen and its visible, but at that time, the web browser refreshes itself and the data what i write into the text boxes are gone.
default:
   // Output notification for undefined values
   TCPPutROMArray(sktHTTP, (ROM BYTE*)"!DEF", 4);
举报
庞晓瑜
2018-11-15 15:01:44
你好Zekigi,MLA TCP/IP库不再被支持。我建议使用TCP/IP光堆栈和签出App Note AN1921:HTTP://www. MyCHIP.COM/WavaPabeSe/AppNo.ASPX?祝你好运!
以上来自于百度翻译
      以下为原文
    Hello zekageri,
The MLA TCP/IP library is no longer being supported.  I would recommend using the TCP/IP Light stack and checking out app note AN1921:
http://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en573940
Best of luck!
举报
更多回帖
