| write_add(0x0,0x5);//CVBS INPUT ON Ain6 | |
| write_add(0x03,0xc);//设置输出格式8bit、422 8位接口 | |
| write_add(0x3C,0xAD);//Setup SOG Sync level for divided down SOG | |
| write_add(0x4,0x47);//HS,VS,F tri-stated | |
| write_add(0x17,0x41);//Select SH1 | |
| write_add(0x1D,0x40);//外部的晶振频率=28M | |
| write_add(0x31,0x0);//Clears NEWAV_MODE, SAV/EAV to suit ADV video encoders | |
| write_add(0x34,0x01);// | |
| write_add(0x35,0x22);// | |
| write_add(0x3A,0x07);//Power down ADC 1 & ADC2 & ADC3 | |
| write_add(0x3C,0xA8);//SOG Sync level for atenuated sync, PLL Qpump to default | |
| write_add(0x47,0x0A);//Enable Automatic PLL_Qpump and VCO Range | |
| write_add(0xBA,0xA0);//Enables Simultaneous Mode (certain HDMI sections kept Active) | |
| write_add(0xF3,0x0F);//Enable Anti-Alias Filters |
举报
引用: yweyerwq 发表于 2018-11-15 19:25
ADV7441A内部是不支持视频处理模块的,所以没有interlace这样的功能。您的这个锯齿问题比较像是奇偶场反了。您可以在后端芯片中将奇偶场调换一下看看是否能解决您的问题。
举报
更多回帖
