是德科技
直播中
尤两畅
8年用户 142经验值
私信 关注
[问答]
N5230C的哪个SCPI用于图片中显示的内存跟踪
全部:有人可以告诉我N5230C的哪个SCPI用于图片中显示的内存跟踪。
我只想选择“内存跟踪”(Trace view Option)按钮。
但我不是SCPI,请帮我解决这个问题,谢谢
以上来自于谷歌翻译
     以下为原文
  All:
Can someone tell me which SCPI of N5230C is for the Memory trace showing in the picture.
I just want to select the “memory trace” (Trace view Option) button. But I do not the SCPI,
Please help me fix this problem, thanks
附件
回帖(4)
尤两畅
2018-11-14 17:07:01
亲爱的Dr_joel:非常感谢你给我一些帮助
以上来自于谷歌翻译
     以下为原文
  Dear Dr_joel:
  please give me some help
thanks very much
举报
仲娜娜
2018-11-14 17:13:13
以上来自于谷歌翻译
不幸的是,SCPI与GUI完全不匹配。
您正在寻找的命令被调用:DISP:WIND:TRAC:MEM - >此命令打开或关闭内存跟踪和DISP:WIND:TRAC:[STATe] - >此命令打开或关闭数据跟踪
一组SCPI命令显示如何设置跟踪并查看内存跟踪:SYST:FPR'清除所有跟踪和窗口DISP:WIND ON'创建窗口#1 CALC:PAR:DEF'myS11',S11'接下来的两行创建
一个S11测量,他们将其命名为“myS11”DISP:WIND:TRAC1:FEED'myS11'CALC:MATH:MEM'将跟踪副本存储为存储器DISP:WIND:TRAC1:MEM 1'打开存储器跟踪DISP
:WIND:TRAC1 OFF'关闭数据跟踪
以上来自于谷歌翻译
     以下为原文
  Unfortunately, the SCPI doesn't match the GUI exactly.
The commands that you are looking for are called:
DISP:WIND:TRAC:MEM   -> this command turns on or off the memory trace
and
DISP:WIND:TRAC:[STATe]  -> this command turns on or off the data trace
This set of SCPI commands shows how to setup a trace and view the memory trace:
SYST:FPR  'clears all traces and windows
DISP:WIND ON ' creates window #1
CALC:PAR:DEF 'myS11',S11     'The next two lines create an S11 measurement and they name it "myS11"
DISP:WIND:TRAC1:FEED 'myS11'
CALC:MATH:MEM    ' Store off a copy of the trace as memory
DISP:WIND:TRAC1:MEM 1   ' Turn on the memory trace
DISP:WIND:TRAC1 OFF   'Turn off the data trace
举报
孔德羲
2018-11-14 17:19:43
引用: 60user56 发表于 2018-11-14 13:28
不幸的是,SCPI与GUI完全不匹配。
一组SCPI命令显示如何设置跟踪并查看内存跟踪:SYST:FPR'清除所有跟踪和窗口DISP:WIND ON'创建窗口#1 CALC:PAR:DEF'myS11',S11'接下来的两行创 ...
如果我们使用TNUM或Calc:Par:Sel关联混淆一个类似的命令,那不是很好。
像“Calc:Par:Tnum Mem On”之类的东西
以上来自于谷歌翻译
     以下为原文
  wouldn't it be nice if we aliased a similar command using TNUM or Calc:Par:Sel association.
Something like "Calc:Par:Tnum Mem On"
举报
刘华湘
2018-11-14 17:27:07
实际上 - 您需要的是此命令“CALC:PAR:MEM [:STAT],因此您可以使用”calc:par:sel“或”calc:par:mnum“选择跟踪,然后您可以打开内存跟踪或
使用我上面提出的命令。
以上来自于谷歌翻译
     以下为原文
  Actually - what you need is this command "CALC:PAR:MEM[:STAT]
so you would select the trace using "calc:par:sel" or "calc:par:mnum" and then you could turn the memory trace on or off using the command I proposed above.
举报
更多回帖
