是德科技
直播中
陈飞
7年用户 1167经验值
私信 关注
[问答]
无法链接到序列库中的外部符号
嗨,我想在外部符号表中保持限制,在不同的测试计划之间共享。
但是在序列库中,我无法链接到外部Symbol表。
按钮显示为灰色!
还有其他方法或解决方法吗?
关心andreas.h
以上来自于谷歌翻译
     以下为原文
  Hi
I'd like to hold limits within an external symbol table, to share it among different testplans.
But within a sequence library, I  can not link to an external Symbol table. The buttons are greyed out!
Is there an other way or work around?
Regards
andreas.h
回帖(2)
邢东
2018-11-12 16:45:44
嗨Andreas,对于TestExec SL的当前架构,我们只允许将testplan本身链接到外部符号表。
允许测试计划内部的用户序列链接到外部符号表。
在考虑以下因素后,这是故意设计的: - 1)符号表的所有链接都被加载到测试计划中。
即使删除了序列库,从已删除序列库链接的外部符号表仍将驻留在测试计划中。
2)我们允许序列库调用其他序列库。
发生这种情况时,如果所有序列库都调用不同的外部符号表。
这些外部符号表将驻留在主序列库中。
在部署到完整的测试计划时,这可能最终会变得麻烦。
我希望这澄清了为什么我们不允许外部符号表在序列库中链接。
谢谢。
此致,辛西娅
以上来自于谷歌翻译
     以下为原文
  Hi Andreas,
For the current architecture of TestExec SL, we only allow the testplan itself to be linked to external symbol table. The user sequence that is internal to the testplan is allowed to link to external symbol table.
This is purposely designed this way after taking into consideration:-
1) All links to symbol tables are loaded into the testplan. Even if the sequence library is deleted, the external symbol tables that was linked from the deleted sequence library will still reside in the testplan.
2) We allows sequence library to call other sequence library. When this happens, if all sequence libraries were to call different external symbol tables. These external symbol table will reside in the main sequence library. And this might end up to be a hassle when deploying into a complete testplan.
I do hope this clarifies why we do not allow external symbol tables to be link in sequence libraries.
Thanks.
Regards,
Cynthia
举报
陈飞
2018-11-12 16:57:57
嗨Cynthia我看,你是对的,只要外部sybol表链接到测试计划而不是序列库本地。
非常感谢andreas.h
以上来自于谷歌翻译
     以下为原文
  Hi Cynthia
I see, you are right, al long as a external sybol table is linked to the testplan and not local to the seqence library.
Thanks anyway
andreas.h
举报
更多回帖
