我有一台运行Windows 2008 Server的英特尔服务器主板S3420GPLX。
然后我在此服务器上安装了Windows Server 2016操作系统。
我通过USB安装了操作系统。
但是,服务器无法启动到已安装的Windows Server 2016操作系统。
它只是在POST消息后显示一个光标。
在引导顺序选项中 - 我尝试更改为从RAID磁盘以及Windows启动管理器启动 - 没有运气。
我在英特尔服务器主板部件号E51974-405上安装了Windows Server 2016。
此服务器运行的是Windows Server 2008.我通过USB驱动器在服务器上安装了Windows Server 2016。
但是,服务器不会引导到已安装的Windows Server 2016操作系统。
它只是在POST消息后显示一个光标。
我还试图在这台服务器上安装Linux CentOs,看它是否会在安装后启动进入操作系统。
我遇到了同样的问题。
另外,我还更改了连接到此服务器的计算机显示器,问题与显示无关。
在这个英特尔服务器主板上成功安装操作系统(Linux或Windows)之后,能否帮助我解释为什么我无法启动已安装的操作系统。
附加映像上的BIOS版本详细信息。
请帮忙。
以上来自于谷歌翻译
以下为原文
I do have an a Intel Server Board S3420GPLX that was running Windows 2008 Server. I then installed Windows Server 2016 OS on this server. I installed the OS via USB. However the server does not boot into the installed Windows Server 2016 OS.
It just show a cursor after POST message. In Boot order options - I have tried to change to boot from RAID disk as well as from Windows Boot Manager - with no luck.
I have installed Windows Server 2016 on Intel Server board Part Number E51974-405. This server was running Windows Server 2008. I installed Windows Server 2016 on the server from a USB drive. However, the server does not boots into the installed Windows Server 2016 OS. It just show a cursor after POST message. In Boot order options - I have tried to change to boot from RAID disk as well as from Windows Boot Manager - with no luck.
I have also tried to install Linux CentOs on this server, to see if it will boot into the OS after installation. I experienced the same issue.
In addition, I also changed computer monitor connected to this server and the issue have nothing to do with the display.
Could you please assist me on why I am not able to boot into installed OS after successfully installing OS (either Linux or Windows) on this Intel Server Board. BIOS Version details on the attached image.
Please help.
