Microchip
直播中
徐晨曦
8年用户 186经验值
私信 关注
[问答]
PIC32 USB入门套件III有教程吗
亲爱的各位,我BUTH PIC32 USB启动器套件III,配备PIX32 MX470,以便做一些实验。通过使用和声框架2.04,我成功地开发了USB供应商设备。现在我想把它修改成MIDI USB设备。有没有可以帮助我的微芯片源代码或教程?非常感谢您的帮助和合作。
以上来自于百度翻译
      以下为原文
    Dear all,
I bougth PIC32 USB starter kit III, equipped with PIX32MX470, in order to make some experiment. I succesfully developed a USB vendor device by using HARMony framework 2.04. Now I would like to modify it into MIDI USB device. Is there any Microchip source code or tutorial  that can help me ?
Thank you very much for your help and cooperation
regards
回帖(6)
唐红菊
2018-11-9 15:50:29
MIDI可能是最简单的USB设备类。它只使用批量传输,标准文档告诉您如何设置所有的内容。事实上,我见过的大多数USB MIDI设备都使用了直接从规范中获取的描述符!
以上来自于百度翻译
      以下为原文
    MIDI is probably the most simple USB device class. It only uses bulk transfers, and the standards document tells you exactly how to set everything up. In fact, most USB MIDI devices I've seen have used descriptors taken directly from the specification!
举报
杨叶
2018-11-9 16:08:27
嗨,从2013年6月的旧PIC32 MLA有USB MIDI使用USB启动工具包的例子。你可以从这里下载旧的MLA:HTTP://www. MicroPC.COM/MLATAB遗留MLA。安装后你可以在文档中找到描述:C:MicroChIP-SoReStsV2013-0615Microchip 帮助MCHPFSU。“旧项目”应该包括USB MIDI的源代码,应该很容易使用到和谐的问候中。
以上来自于百度翻译
      以下为原文
    Hi,
The old PIC32 MLA from june 2013 has examples for USB midi using USB starter kit II.
you can download that old MLA from here : http://www.microchip.com/MLA tab  Legacy MLA.
After installation you can find the description in the documentation :
c:microchip_solutions_v2013-06-15MicrochipHelpMCHPFSUSB Library Help.chm
the "old project" should include the source code for USB MIDI which should be easily usable into Harmony
Regards
举报
薛珊珊
2018-11-9 16:25:17
你有一些和谐的例子吗?重排
以上来自于百度翻译
      以下为原文
    do you have some Harmony example ?
regrds
举报
杨叶
2018-11-9 16:31:05
嗨,我仔细阅读了我的文章,我写了你需要把MLA代码调到和谐。如果有一个和谐的USB MIDI例子,我不会提出一个更复杂的方法…否则,你可以从头开始,并根据USB HID MIDI规范来创建它。
以上来自于百度翻译
      以下为原文
    Hi,
I you read carefully my post I wrote that you need to adapt the MLA code into Harmony.
If there was an Harmony USB Midi example, I would not propose a more complex method...
Otherwise, you can start from scratch and create it yourself based on the USB HID Midi specification
Regards
举报
更多回帖
