英特尔
直播中
段丽
8年用户 161经验值
私信 关注
[问答]
无法解决0xa001004b错误
嗨!
安装Optane软件时出现0xa001004b错误。
我完成了磁盘管理中的缩小卷。
什么都没有帮助。
我的配置看起来像这样。
M2 Plextor 256 GB(适用于Windows),Toshiba SATA 1TB HDD(用于Optane加速),Optane 32GB内存在第二个M2端口。
安装了所有最新的驱动程序。
哪个驱动0xa001004b错误关注?
系统驱动器(我不想加速)或硬盘驱动器?
附加日志。
一切都好!
IntelOptaneMemory.log.zip
209.8 K.
以上来自于谷歌翻译
以下为原文
Hi! While installing Optane software I got 0xa001004b error. I got through Shrinking Volume in Disk Management. Nothing helps. My configuration looks like this. M2 Plextor 256 GB (for Windows), Toshiba SATA 1TB HDD (for Optane acceleration), Optane 32GB memory on second M2 port. All newest drivers are installed.
Which drive the 0xa001004b error concernes? System drive (which I don't want to accelerate) or HDD drive?
Log attached.
All best!
回帖(4)
汤宇
2018-11-8 11:17:54
您好Aky,感谢您联系英特尔技术支持。据我们了解,您需要有关英特尔®Optane™内存系列(32GB,M.2 80mm PCIe 3.0,20nm,3D Xpoint)的帮助。
如果我们正确推断,要开始诊断和随后的故障排除可能需要我们解决,我们将非常感谢您,请回复此帖,并提供以下重要的基本信息:
系统集成(请描述您的系统是如何集成的;请包括所有组件的制造商和型号)回答您的问题:“哪个驱动器出现0xa001004b错误?
系统驱动器(我不想加速)或硬盘驱动器?“它将与两个驱动器相关,但当你尝试使用Optane时,这始终是主驱动器的特定要求,考虑到它永远不会
建议尝试加速没有可用空间的二级驱动器。我们期待您的回复。最好的问候,Josh B.Intel客户支持技术人员与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello Aky,
Thank you for contacting Intel Technical Support.
As we understand, you need assistance with your Intel® Optane™ Memory Series (32GB, M.2 80mm PCIe 3.0, 20nm, 3D Xpoint). If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, we would appreciate if you could, please, reply to this post with the following, important, basic information:
  • System Integration (please, describe how your system is integrated; please, include the manufacturer and model of all the components)
To answer your question:
“Which drive the 0xa001004b error concerns? System drive (which I don't want to accelerate) or HDD drive?”
It will be related to both drives, but this is always a specific requirement for the primary drive when you try to use Optane, take into consideration that it is never recommended to try to accelerate a secondary drive that does not have free space available.
We will be looking forward to your reply.
Best regards,
Josh B.
Intel Customer Support Technician
Under Contract to Intel Corporation
举报
李玉鑫
2018-11-8 11:37:40
系统集成(请描述您的系统是如何集成的;请包括所 ...
嗨!
感谢您的回复。
我自己设法解决了这个问题。
我做错了就是在驱动器末端制作免费的,未分配的空间。
我能够做到这一点,但这个未分配的空间总是出现在分区内,在其他空间之间。
为了正确地做到这一点,我不得不购买软件,我无法使用Windows磁盘管理。
如果您知道如何使用此Windows工具执行此操作,请制作一些手册。
除了这个问题,我还有另外一个。
我的MB有两个M2端口(32G和16G)。
安装nvme sdd的速度越快,另一个就是optane内存。
但我的MB制造商为Optane安装选择了一个m2端口(速度更快)。
所以我不得不卖掉我的nvme驱动器并为pcie连接器购买新的驱动器。
所以这是对所有想要购买非顶级主板的用户的警告。
首先检查您的文档。
最好的祝福!
以上来自于谷歌翻译
以下为原文
Hi! Thanks for reply.
I did manage to solve this problem myself. What I did wrong was making free, unallocated space not at the end of the drive. I was able to do it but this unalocated space was always emerging inside the partition, between other spaces. To do that correctly I had to buy software, I wasn't able to make it using Windows Disk Management. If You know how to do this using this Windows tool please make some manual.
Besides this problem I had another one. My MB have two M2 ports (32G and 16G). The faster one had nvme sdd installed and the other was for optane memory. But my MB manufacturer selected one m2 port (the faster one) for Optane installing. So I had to sell my nvme drive and buy new one for pcie connector. So this is warning for all users which want to buy non-top motherboards. Check Your documentation first.
Best regards!
举报
汤宇
2018-11-8 11:51:07
引用: cd340823 发表于 2018-11-8 09:37
嗨!
感谢您的回复。
我自己设法解决了这个问题。
您好Aky,感谢您的回复。我们很高兴听到您能够解决您遇到的问题,我们想知道您是否需要进一步的帮助,或者我们是否可以关闭此案例?重要说明:是否需要进一步的帮助或
需要澄清,如果您回复此帖子而不是写一个新帖子,我们将非常感谢,除非您的询问完全无关。
通过这种方式,我们将防止生成重复的帖子,我们不会失去思路。我们期待您的回复。最好的问候,Josh B.Intel客户支持技术人员与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello Aky,
Thank you for your reply.
We are glad to hear you were able to resolve the issue you were experiencing and we would like to know if you need further assistance or if we can close this case?
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
Best regards,
Josh B.
举报
段丽
2018-11-8 12:08:18
通过这种方式,我们将防止生成重复的帖子,我们不会失去思路。 ...
您好Aky。感谢您联系了英特尔技术支持。
自上次沟通以来,我们没有收到您的回复,我们想知道您是否需要进一步的帮助,或者我们是否可以结案;重要提示:如果需要进一步的帮助或澄清,如果您回复此帖子,我们将不胜感激。
除非您的询问完全不相关,否则不要写新的。
通过这种方式,我们将防止生成重复的帖子,我们不会失去思路。我们期待着您的回复。最好的问候,Josh B.Intel客户支持。
以上来自于谷歌翻译
以下为原文
Hello Aky.
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case?
Best regards,
Josh B.
Intel Customer Support.
举报
更多回帖
