@yatish,
检查这个帖子:
https://forums.xilinx.com/t5/Implementation/DRC-23-20-Rule-Violation-LUTLP-1/td-p/674253
--Syed
-------------------------------------------请注意 - 请标记答案
如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@yatish,
Check this thread:
--Syed
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
---------------------------------------------------------------------------------------------View solution in original post
@yatish,
检查这个帖子:
--Syed
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
@yatish,
Check this thread:
--Syed
举报
