谢谢您的回复。
我使用isdct工具更改Intel Optane SSD DC P4800X上的SectorSize。
(我暂时没有找到P4500的磁盘。)
我发现扇区大小可以在512到4096之间切换。当我尝试将SectorSize更改为4160时。报告了一个错误。
所以我的问题是:英特尔SSD DC P4500 / P4510与英特尔Optane SSD DC P4800X相同,是否支持VSS功能,但它也不能
改为4160?
谢谢。
$ sudo isdct start -intelssd 0 -NVMeFormat LBAformat = 5 SecureEraseSetting = 0 ProtectionInformation = 0 MetaDataSettings = 0
警告!
您已选择格式化驱动器!
继续格式化?
(Y | N):Y
格式化...(这可能需要几分钟才能完成)
- 英特尔Optane(TM)SSD DC P4800X系列PHKE736100RS375AGN -
状态:NVMe命令报告了一个问题。
并将SectorSize更改为4096.它成功了。
$ sudo isdct start -intelssd 0 -NVMeFormat LBAformat = 3 SecureEraseSetting = 0 ProtectionInformation = 0 MetaDataSettings = 0
警告!
您已选择格式化驱动器!
继续格式化?
(Y | N):Y
状态:NVMeFormat成功。
以上来自于谷歌翻译
以下为原文
Thank you for your reply.
I use isdct tool to change the SectorSize on Intel Optane SSD DC P4800X. (I haven't found the disk of P4500 for the time being.)
And I found Sector size can be switched between 512 and 4096. when I try to change the SectorSize to 4160. A mistake was reported.
So My question is : Does the Intel SSD DC P4500/P4510 the same with Intel Optane SSD DC P4800X support VSS function, but It also can't
change to 4160? Thank you.
$sudo isdct start -intelssd 0 -NVMeFormat LBAformat=5 SecureEraseSetting=0 ProtectionInformation=0 MetaDataSettings=0
WARNING! You have selected to format the drive!
Proceed with the format? (Y|N): Y
Formatting...(This can take several minutes to complete)
- Intel Optane(TM) SSD DC P4800X Series PHKE736100RS375AGN -
Status : NVMe command reported a problem.
And change the SectorSize to 4096 .It was succeed.
$sudo isdct start -intelssd 0 -NVMeFormat LBAformat=3 SecureEraseSetting=0 ProtectionInformation=0 MetaDataSettings=0
Status : NVMeFormat successful.
谢谢您的回复。
(我暂时没有找到P4500的磁盘。)
改为4160?
谢谢。
警告!
您已选择格式化驱动器!
继续格式化?
(Y | N):Y
状态:NVMe命令报告了一个问题。
警告!
您已选择格式化驱动器!
继续格式化?
(Y | N):Y
状态:NVMeFormat成功。
以上来自于谷歌翻译
以下为原文
举报
