您好MinecraftGDI,感谢您联系了英特尔®技术支持。据我们了解,在您将硬盘移至另一个系统后,无需关闭Optane即可获得与英特尔®Optane™内存技术相关的帮助。
如果我们正确推断,请在下面找到一些信息和建议:•基于英特尔®Optane™内存的常见问题解答可以在启用英特尔®Optane™内存后断开我的SATA驱动器并将其移至另一台计算机?不,你
必须先禁用Intel®Optane™内存,然后才能将其移至另一台计算机。
您可以通过Intel®Optane™内存或Intel RST应用程序禁用它。
有关详细信息,请参阅“英特尔Optane内存用户和安装指南”或视频。•据说我们建议您将用于加速此驱动器的HDD和英特尔®Optane™内存连接回原始硬件(如果有)
或兼容的硬件,并按照上面分享的指南。
如果您无法执行此过程,则使硬盘再次有用的唯一方法是执行格式化过程,删除硬盘中的所有分区和信息,并在完成此过程后将数据移回驱动器
你的备份(如果你有的话)。我们希望你发现这些信息很有用。最好的问候,Josh B.Intel客户支持技术人员与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello MinecraftGDI,
Thank you for having contacted Intel® Technical Support.
As we understand, you need assistance related to Intel® Optane™ Memory Technology after you moved your HDD to another system without turning your Optane off. If we infer correctly, please find some information and recommendations below:
• Based on the
Frequently Asked Questions for Intel® Optane™ Memory
Can I disconnect my SATA drive after it's enabled with Intel® Optane™ memory and move it to another computer?
No, you have to disable Intel® Optane™ memory before you can move it to another computer. You can disable it via the Intel® Optane™ memory or Intel RST applications. Refer to the Intel Optane Memory User and Installation Guide or video for more information.
• This being said our recommendation is to connect your HDD and the Intel® Optane™ Memory that you used to accelerate this drive back to the original hardware (if available) or to a compatible hardware and follow the guide shared above. If you are not able to do this process the only way to make your HDD useful again will be to do a format process deleting all the partitions and information in the hard drive and after this process is done to move the data back to your drive from your back up( in case that you have one).
We hope you find this information useful.
Best regards,
Josh B.
Intel Customer Support Technician
Under Contract to Intel Corporation
或兼容的硬件,并按照上面分享的指南。
以上来自于谷歌翻译
以下为原文
Hello MinecraftGDI,
• Based on the
Best regards,
Josh B.
举报
