德州仪器
直播中
刘平
8年用户 240经验值
私信 关注
[经验]
初始状态
本博客旨在讨论Initial State提供的分析服务。
可以购买两种不同的许可证:标准和专业。
此分析工具旨在将数据流式传输到初始状态仪表板,以便监控来自浏览器的设备和事件。
此服务可以处理任何可以发出HTTP请求或可以输出数据在线流式传输的内容。
对于用户想要远程监控的任何内容,这是一个很好的工具。
它有助于显示活动趋势,峰值事件,触发事件等。
该服务采用正在流式传输的数据,并以用户选择的方式以图形方式表示信息。
在完成这个项目的过程中,我能够从热探针传输数据,并通过簧片开关和磁铁执行器打开和关闭门。
右边的例子显示温度探头的数据使用华氏温度和摄氏温标,当我把它保温起来,然后把它放回去让它冷却下来:
如果在输出数据的系统中存在需要监控的情况,则该服务绝对值得关注。
有关该产品的更多信息可以在EEWiki上找到,并随时在TechForum中提出任何问题。
以上来自于谷歌翻译
以下为原文
This blog is meant to talk about the analytics service provided by Initial State. There are two different licenses that can be purchased: the standard and the professional. This analytics tool is meant to stream data onto the Initial State dashboard in order to monitor devices and events from a browser. This service can work with anything that can make an HTTP request or that can output data to be streamed online.
This is a great tool for anything that the user would like to remotely monitor. It helps to show trends in activity, peak events, triggered events, and more. The service takes the data that is being streamed in and graphically represents the information in the manner of the user’s choosing. While working through this project, I was able to stream data from a thermal probe and open and close a door with a reed switch and magnet actuator. The example on the right shows the data from the temperature probe using Fahrenheit and Celsius scales when I held it to wARM it up, then put it back to let it cool back down:
If there is a situation that needs to be monitored in a system that outputs data, this service is definitely worth looking at. More information about this product can be found on EEWiki, and feel free to ask any questions in the TechForum.
更多回帖
