你好,
我在Xilinx Vivado中遇到了累加器(Add)的问题。
我用VHDL编写了程序。
实施时会出现以下错误:
信息:[DRC 23-20]规则违规(AVAL-4)enum_USE_DPORT_FALSE_enum_DREG_ADREG_0_connects_CE·D_CEAD_RSTD_GND - fpAccOne_Stage1 / U0 / i_synth / ACCUM_OP.OP / g_accum_split [0] .g_dsp_split.i_adder / DSP:DSP48E1未使用D端口(USE_DPORT = FALSE)
为了改善功耗特性,将DREG和ADREG设置为1,将CED,CEAD和RSTD连接到逻辑'0'。
如何在Xilinx IP中纠正此规则违规。
我的组件:
组件fpAcc
港口 (
aclk:IN STD_LOGIC;
aclken:IN STD_LOGIC;
aresetn:IN STD_LOGIC;
s_axis_a_tvalid:IN STD_LOGIC;
s_axis_a_tdata:IN STD_LOGIC_VECTOR(31 DOWNTO 0);
s_axis_a_tlast:IN STD_LOGIC;
s_axis_opera
tion_tvalid:IN STD_LOGIC;
s_axis_operation_tdata:IN STD_LOGIC_VECTOR(7 DOWNTO 0);
m_axis_result_tvalid:OUT STD_LOGIC;
m_axis_result_tdata:OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
m_axis_result_tlast:OUT STD_LOGIC
结束组成部分;
实例:
fpAccOne_Stage1:fpAcc
港口地图(
aclk => clockIn,
aclken =>'1',
aresetn => aresetn_Stage1,
s_axis_a_tvalid => s_axis_a_tvalid_Stage1,
s_axis_a_tdata => inA_Stage1,
s_axis_a_tlast => s_axis_a_tlast_Stage1,
s_axis_operation_tvalid => s_axis_operation_tvalid_Stage1,
s_axis_operation_tdata =>“00000000”,
m_axis_result_tvalid => m_axis_result_tvalid_Stage1,
m_axis_result_tdata => outA_Stage1,
m_axis_result_tlast => m_axis_result_tlast_Stage1
我已将值指定为
我是否正确分配了
对于消息:将DREG和ADREG设置为'1',将CED,CEAD和RSTD连接到逻辑'0',如何使用IP目录/ IP的重新声明来分配这些值?
我在Verilog看到了对类似问题的回复:
https://forums.xilinx.com/t5/Implementation/Drc-23-20-Rule-violation-AVAL-4-enum-USE-DPORT-FALSE-enum-DREG/m-p/549620#M11094
但我没有得到任何答案。
以上来自于谷歌翻译
以下为原文
Hello,
I have a problem with the Accumulator (Add) in Xilinx Vivado.
I have written the program in VHDL.
The following error is coming up while implementation:
INFO: [DRC 23-20] Rule violation (AVAL-4) enum_USE_DPORT_FALSE_enum_DREG_ADREG_0_connects_CED_CEAD_RSTD_GND - fpAccOne_Stage1/U0/i_synth/ACCUM_OP.OP/g_accum_split[0].g_dsp_split.i_adder/DSP: DSP48E1 is not using the D port (USE_DPORT = FALSE). For improved power characteristics, set DREG and ADREG to '1', tie CED, CEAD, and RSTD to logic '0'.
How can I rectify this rule violation in Xilinx IP.
My component :
COMPONENT fpAcc PORT ( aclk : IN STD_LOGIC; aclken : IN STD_LOGIC; aresetn : IN STD_LOGIC; s_axis_a_tvalid : IN STD_LOGIC; s_axis_a_tdata : IN STD_LOGIC_VECTOR(31 DOWNTO 0); s_axis_a_tlast : IN STD_LOGIC; s_axis_operation_tvalid : IN STD_LOGIC; s_axis_operation_tdata : IN STD_LOGIC_VECTOR(7 DOWNTO 0); m_axis_result_tvalid : OUT STD_LOGIC; m_axis_result_tdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); m_axis_result_tlast : OUT STD_LOGIC );END COMPONENT;
Instantiation:
fpAccOne_Stage1 : fpAcc PORT MAP ( aclk => clockIn, aclken => '1', aresetn => aresetn_Stage1, s_axis_a_tvalid => s_axis_a_tvalid_Stage1, s_axis_a_tdata => inA_Stage1, s_axis_a_tlast => s_axis_a_tlast_Stage1, s_axis_operation_tvalid => s_axis_operation_tvalid_Stage1, s_axis_operation_tdata => "00000000", m_axis_result_tvalid => m_axis_result_tvalid_Stage1, m_axis_result_tdata => outA_Stage1, m_axis_result_tlast => m_axis_result_tlast_Stage1 ); I have assigned the values as
s_axis_operation_tvalid_Stage1 <= '0';s_axis_a_tlast_Stage1 <= '0';aresetn_Stage1 <= '0';
Did I assign correctly.
For the message :
set DREG and ADREG to '1', tie CED, CEAD, and RSTD to logic '0', how to assign these values using IP Catalog/Recostumization of IP?
I have seen the reply to a similar question in Verilog here:
but I did not get any answer.
