你好,
不幸的是,ST没有mpc563mzp66等效零件号,因为该产品不包含在联盟范围内开发的产品中。
无论如何,您可以使用Home - >部分中的产品选择器找到符合您需求的ST产品。感觉和电力和汽车产品 - >汽车微控制器 - > SPC5 32位汽车MCU(直接网址http://www.st.com/web/en/catalog/sense_power/FM2098/SC963
一般来说,确定一个等同于FSL的ST产品是正确的,在S中交换M是不够的:所以我们提供的是ST WEB页面中的交叉引用搜索引擎。
它与用于搜索ST WEB(位于每个ST WEB页面的右上角)相同:您只需输入FSL部件号,在开始搜索之前,从''部件号/关键字切换搜索选项''到''交叉参考''。
无论如何,如有疑问,只需在论坛中输入另一个项目即可。
以上来自于谷歌翻译
以下为原文
Hello,
unfortunately ST has no mpc563mzp66 equivalent part number since the product is not included in the ones developed in the scope of the alliance.
Anyway you may find an ST product matching your needs by using the product selector in the section Home -> Sense & Power and Automotive Products -> Automotive Microcontrollers ->SPC5 32-bit Automotive MCUs (direct URL http://www.st.com/web/en/catalog/sense_power/FM2098/SC963
Generally speaking it is true that to identify an ST product equivalent to a FSL one, it is not enough to swap M in S: so what we are offering is a cross reference sear engine in the ST WEB pages.
It is the same used to search on the ST WEB (positioned on top right of every ST WEB pages): you have simply to enter the FSL part number, and before starting the search, switch the search option from ''Part Number/ Keyword'' to ''Cross Reference''.
Anyway, in case of doubt, just enter another item in the forum.
你好,
以上来自于谷歌翻译
以下为原文
Hello,
举报
