Microchip
直播中
李天童
8年用户 188经验值
私信 关注
[问答]
编程后将MCLR设置为三态?
我有一个使用MCLR作为输入的项目。用PICtiT2 MCLR放在编程后的三态,但是用皮卡4,似乎PIN保持高。这有什么设置吗?
以上来自于百度翻译
      以下为原文
    I have a project that uses MCLR as input. With Pickit2 MCLR is put to tristate after programming however with Pickit 4 it seems the pin is held HIGH. Is there a setting for this?
回帖(7)
苗雨
2018-10-26 16:30:54
在编程后,您是否试图使用MCLR作为通用I/O?我不相信你能做到这一点。它致力于MCLR对所有我工作的设备,所以我不知道你可以如何使用它作为除MCLR以外的任何东西。
以上来自于百度翻译
      以下为原文
    Are you trying to use MCLR as general purpose I/O after programming? I don't believe that you can do that. It's dedicated to MCLR on all of the devices I've worked with, so I don't see how you could use it as anything other than MCLR.
举报
杨万富
2018-10-26 16:49:04
是的,我用它作为输入。设备是PIC16F1828。
以上来自于百度翻译
      以下为原文
    Yes I am using it as input. Device is PIC16F1828.
举报
石双厚
2018-10-26 16:56:00
在您没有使用它的设备上没有专用于MCLR。
以上来自于百度翻译
      以下为原文
On devices you haven't worked with it is not dedicated to MCLR.
举报
傅双育
2018-10-26 17:11:14
我们发现,从RESET释放是不正确的皮卡4,我们正在进行一个修复工作,并希望将在四月发布的MPLAB X。
以上来自于百度翻译
      以下为原文
    We have found that release from reset is not working correctly with PICkit 4 we are working on a fix, and hopefully will be in the April release of MPLAB X.
举报
更多回帖
