您好rlippmann,感谢您加入我们的英特尔®社区。我们了解您遇到的英特尔®NUC套件NUC7i7BNH的以太网连接(I219-V)存在问题。在这种情况下,请考虑英特尔®不测试和验证
英特尔®NUCon Linux *,但是我们知道许多NUC用户正在使用许多不同的Linux发行版.Intel®建议你查看Linux的Ubuntu *网站和论坛,以获得有关此安装问题的同行帮助。你的问题是
体验似乎是由于驱动程序兼容性问题,因为您的设备唯一支持的操作系统是Windows®10,64位*(Home和Pro版本),您可以在这里查看。但是,您可以尝试我们的英特尔®以太网适配器完整驱动程序
包。
并非所有版本的Windows *,Linux *或FreeBSD *都支持所有英特尔®以太网适配器和英特尔®以太网控制器,因此我们不保证这些驱动程序会对您的问题产生影响。我希望这有助于.Regards,
迭戈S.
以上来自于谷歌翻译
以下为原文
Hello rlippmann,
Thank you for joining our Intel ® Community.
I understand that you are experiencing issues with the Ethernet Connection (I219-V) of your Intel® NUC Kit NUC7i7BNH.
In this case, please consider that Intel® does not test and validate Intel® NUC on Linux*, however we know that a lot of NUC owners are using is successfully on many different Linux distros.
Intel ® suggests you check Linux’s Ubuntu*
website and
forums for peer assistance with this installation issue.
The issue that you are experiencing seems to by a driver compatibility issue, since the only supported OS for your unit is Windows® 10, 64-bit*(Home and Pro editions) as you can check
here.
However, you can try our
Intel® Ethernet Adapter Complete Driver Pack. Not all Intel® Ethernet Adapters and Intel® Ethernet Controllers are supported under every version of Windows*, Linux*, or FreeBSD*, so we do not guarantee that these drivers will have an impact on your issue.
I hope this helps.
Regards,
Diego S.
包。
迭戈S.
以上来自于谷歌翻译
以下为原文
Hello rlippmann,
website and
here.
I hope this helps.
Regards,
Diego S.
举报
