ST意法半导体
直播中
张小林
7年用户 182经验值
私信 关注
[问答]
STM8S操作码列表找不到
我看了但是找不到这个MCU的操作码的完整列表。我正在使用STM8S-Discovery来教我的孩子编程,从最基本的机器语言开始,然后是汇编程序,然后是C.我希望它们能够读取由高级语言生成的代码。我发现程序员手册中列出了大约80个代码,但这不是整套代码。有没有人知道是否已经发布了一整套,或者如果我创建了一整套就会有人反对。
以上来自于谷歌翻译
以下为原文
I have looked but can't find a ''complete listing of the op-codes for this MCU.  I'm using the STM8S-Discovery to teach my grand-kids programming, starting at the very basic machine language, then to assembler and then C.  I want them to be able to read the code that is generated by the high level language.   I found about 80 codes listed in the programers manual, but that is not the entire set.  Does anyone know if a full set has been published, or if anybody would object if I created one.
回帖(2)
陈伟
2018-10-25 10:54:55
我不知道这里的外围设备手册是stm8s的cpu手册
http://www.st.com/web/en/resource/technical/document/programming_manual/CD00161709.pdf
但似乎不包含写入模数转换器dac或uart或gpio的指令。我正在建立一个反汇编程序。我需要在sourceforge上发布它。我得到它来识别所有的CPU指令。但我找不到perifferal访问指令
以上来自于谷歌翻译
以下为原文
i don't know where a manual for the peripherals here is the cpu manual for the stm8s
but it appears that that does not contain the instructions for writing to the analog to digital converter dac or uart or gpio   . i am building a disassembler. i need to publish it on sourceforge. i got it to recognise all the cpu instructions. but i can't find the perifferal access instructions
举报
李淳鑫
2018-10-25 11:03:25
所有I / O都在STM8中进行内存映射。一个简单的ld(x),a可以根据x的值进行I / O.
 菲利普
以上来自于谷歌翻译
以下为原文
All I/O is memory mapped in the STM8. A simple ld (x), a can do I/O depending on the value of x.
Philipp
举报
更多回帖
